Rim size question?
Old Oct 31, 2016 | 07:29 AM
amh986's Avatar
amh986
Default Rim size question?
What is the largest rim size height and with in can put on a non z51 stingray?
Old Oct 31, 2016 | 07:54 AM
Little Red Corvette1's Avatar
2016 C7 of the Year Finalist
Default Rim Size
i have Forgelines: 21" X 11" in the rear and 20" X 9" up front.
305's and 265's (tires).
For me, this requires a -1 degree camber.
Old Oct 31, 2016 | 08:08 AM
amh986's Avatar
amh986
You have no issues with rubbing? I want to give my car a lower look without dropping ride height. The body kit I have already is low enough to the ground.
Old Nov 3, 2016 | 09:00 PM
X25's Avatar
X25
Sr.Random input generator
You should also consider suspension height, camber of wheels and height/width of tires as important parameters. For instance, my 19x11.5" ET83 wheels with 305/30/19 tires do not rub, while the taller and wider 325/30/19 did rub at the track (but not at the street). Actually, I'd not go any taller than those, since they also barely clear the bumper side of fender liners.
Old Nov 3, 2016 | 10:31 PM
Chets LS3's Avatar
Chets LS3
thats not really apples to apples because a 325/30/19 is shorter than the factory tire. we just have problems trying to shove too wide of tires and it creates issues under load (The track guys that is) etc. 325/30 is about 1/2 tenth shorter than stock. I personally run a 295/30/20 on my street tires which is about 2/10s taller and I rubbed a very small amount (26.9x height) But on the flip side I can run a 305 pirelli at 27.33 tall with more camber and have very little issues.
Old Nov 4, 2016 | 08:16 PM
amh986's Avatar
amh986
So I bought some take off c7 zo6 rims 20 rear 19 front what tires will be appropriate for not rubbing? Sorry guys I'm not very educated.
Old Nov 4, 2016 | 08:19 PM
Chets LS3's Avatar
Chets LS3
Those definitely won't work!!!
Old Nov 4, 2016 | 08:23 PM
amh986's Avatar
amh986
Are they to wide? Or tall
Old Nov 4, 2016 | 08:30 PM
Chets LS3's Avatar
Chets LS3
Too wide. There 19x10/20x12
Old Nov 4, 2016 | 08:39 PM
amh986's Avatar
amh986
Well crap time to start modifying the wheel well or get new rims
Old Nov 4, 2016 | 09:32 PM
X25's Avatar
X25
They're not necessarily too wide, but the offset is wrong, and they will stick out.
Old Nov 6, 2016 | 01:44 PM
savage's Avatar
savage
take it from a guy ( me) that put wheels on my 2014 base car with the wrong offsets ! I busted out the rear inner fender lips and the quarters cracked all over , not much better luck in the front- it was cheaper to trade the car than fix it - not kidding, offsets mean a lot followed by tire size .
Old Nov 7, 2016 | 06:14 PM
Bob Z.'s Avatar
Bob Z.
So for those of us that plan to replace our stock wheels is there a range of offsets we can use or should be stick with the stock offset, whatever that is. For example, I plan to replace the Black OEM 18/19" wheels/tires off my '17 when it arrives with 19/20". I know the tires I select will come into play but my objective is going as big as I can with clearance issues.
Old Nov 7, 2016 | 06:20 PM
X25's Avatar
X25
Factory offsets are great in terms of letting you know how to even out the available space in between fender and inside. That said, as you push the limits, you'll have to make minor changes in offsets to increase your clearance. Keep in mind, offsets are different between Stingray/Z51 and GS/Z06.
Below is a great setup:
18x10.5 ET56 (same offset as OEM) front
19x11.5 ET83 (a little more tucked in than OEM) rear.
OEM offsets (from my notes)
Front: 19-inch x 8.5-inch 56mm offset (with Z51)
Rear: 20-inch x 10-inch 79mm offset (with Z51)
Old Nov 8, 2016 | 04:41 PM
Bob Z.'s Avatar
Bob Z.
For my base Stingray, how about 19 x 9.5 / 20 X 11 (Cray Brickyards)? I need to verify offsets. Since the Z51 cars come with 19/20 I should be ok I guess, as long as I use correct offsets and tires that is.
Old Nov 8, 2016 | 04:49 PM
X25's Avatar
X25
AFAIK, those Cray wheels are being manufactured specifically for Corvettes, so you need not fear.
Check it out:
http://www.craycorvettewheels.com/
Old Nov 8, 2016 | 05:04 PM
Bob Z.'s Avatar
Bob Z.
Check it out:
Yeah, that is why I am leaning toward them; however, I guess I still need to consider the offset if I am going up, right? Again, my base Stingray comes with 18/19s and I want 19/20s and I see there are 2 Cray options: 19x9 or 19x9.5 / 20x10.5 or 20x11.
Old Nov 8, 2016 | 05:05 PM
X25's Avatar
X25
They show which ones are for front and rear in their fitment guide. Z51 and regular Stingray should be the same (which they indicate by C7 fitment).
Old Nov 8, 2016 | 05:14 PM
Bob Z.'s Avatar
Bob Z.
On a side note I looked up what the cost of my stock 18/19 Black OEM wheels cost (2017 Stingray) and it appears they are between $500 & $600 - really!? Add in the tires and it seems that a set new would be about close to $3k but based on what I saw in the classifieds I'd be lucky to get half that.
To Rim size question?
