Ceramic Z06 brakes
Old Nov 15, 2016 | 08:49 AM
2016 first zo6's Avatar
2016 first zo6
Default Ceramic Z06 brakes
I know there are kits for a full conversion from steel rotor to ceramic set up. Does anyone know if it is more than just changing the rotors and brake pads?
If so, what else is involved in it.
GM has the ceramic rotors on sale now 44% off. $2900 down to $1600.
Thats one hell of a discount. I was thinking about getting all 4 now and figure out what else is required.
Thanks.
Old Nov 15, 2016 | 09:26 AM
fleming23's Avatar
fleming23
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
First, the most obvious issue is the rotor size would not work. The non CCB car has 14.6" front rotors, the CCB is 15.5, the caliper would not be positioned correctly to fit.
Old Nov 15, 2016 | 03:41 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Supporting Vendor
Correct, we would needs all new rotors and pads.. Which is going to cost a pretty penny..
-Josh
Old Nov 16, 2016 | 01:15 AM
Bill Dearborn's Avatar
Bill Dearborn
2 front calipers $1800 + from GM Parts Direct depending on color
2 rear calipers $1450 from GM Parts Direct depending on color
1 set of front brake pads $586 from GM Parts Direct
1 set of rear brake pads $606 from Amazon
2 front rotors $2600 from Amazon
2 rear rotors $3400 from Amazon
Total $10,422 not a cheap upgrade that doesn't do much for you other than look cool.
Bill
Old Nov 16, 2016 | 03:45 PM
tyho's Avatar
tyho
C7 of Year Finalist (performance mods) 2019
It would be nice if someone built a ceramic rotor that fits a z51 or base C7, without having to change everything else. I would be in line to buy one ... provided the price is reasonable.
Old Nov 16, 2016 | 07:51 PM
MerakiAutoworks
Supporting Vendor
Some motorsport team out there should..
-Josh
To Ceramic Z06 brakes
