Z51 drag set up
Old Jan 23, 2017 | 06:12 PM
COALMINER,KY's Avatar
COALMINER,KY
Default Z51 drag set up
what does everyone recommend? I will be around 725 rwhp?
Old Jan 24, 2017 | 10:39 AM
robert miller's Avatar
robert miller
Just look at getting the smallest rim like a 17 are 18 rim so you can get the tallest tire on the rear. Plus a 5 are 7 inch wide rim on the front.
Old Jan 24, 2017 | 02:37 PM
blue_bomber697's Avatar
blue_bomber697
2018 C7 of Year Finalist
Can we fit 17's on our cars? I was under the impression 18" was as low as we could go without a conversion.
And to OP: An 18x10.5/11" rear with a 315 tire is pretty cost effective. The Mickey Thompson tires probably give the most grip from a DR, but have had mixed reports of stability. The NT05R is a popular option which has good grip, and excellent stability. Running skinnies up front would also help things at the strip if you want to take it a step further.
Old Jan 24, 2017 | 03:01 PM
COALMINER,KY
Only problem is they don't make a 315 Mickey in 18 or 19 inch
Old Jan 24, 2017 | 07:13 PM
blue_bomber697
305's won't have much a difference in grip.
Old Jan 24, 2017 | 08:33 PM
Robnelson54's Avatar
Robnelson54
You could also check out M&H. I haven't personally ran them, I'm still on MT street.. but I know a bunch of c6 and c7 friends that have the or are switching to them.
http://www.mandhtires.com/M-H-Drag-Tires/M-H-Drag-Radials
Old Jan 24, 2017 | 11:41 PM
phantom1's Avatar
phantom1
[QUOTE=blue_bomber697;1593940138]Can we fit 17's on our cars? I was under the impression 18" was as low as we could go without a conversion.
I know 17" Race Stars don't fit, not sure about any other 17" wheels.
Old Jan 25, 2017 | 08:16 AM
C7&7's Avatar
C7&7
You could run a c5z wheel and like a 305/40/18. Pretty sure this setup has been done by a few forum members. StangKillerProductions runs this setup if I am not mistaken.
Old Jan 28, 2017 | 09:01 AM
kwhoermann's Avatar
kwhoermann
5th Gear
You can run my Forgelines. MT 305s. 18 in. 17 inch rims won't work.
Old Jan 28, 2017 | 01:17 PM
Spulbus2013's Avatar
Spulbus2013
I am using the 285/40/18 MT ET Streets on a C5Z replica rim, works 100% fine for dig racing! No rubbing, no issues,
^14 C7 A6 Z51 (slightly lowered but not all the way on stock bolts)
I have noticed some swaying at higher speeds with these tires so i normally only will dig race with them and currently keep them around 26psi, Im full bolt on and E85 and can dig pretty good with them on the street with a quick scrub of the tire and rpm to 1500-1800 then let it go with all the nannies off.
@2000+rpms they will spin, i bet i could drop pressure to 20-22psi and they would stick but would probably become more unstable at speed too.
Old Jan 28, 2017 | 04:56 PM
phantom1's Avatar
phantom1
FS: Set of TSW Interlago Machine finish with Mirror Cut Face. Fronts 18"x 5" 17 lbs each narrowed by Eric Vaughn Machine. Rears 18"x 10.5" 20.74 lbs each. Wheels are in excellent condition, except for 2 small scratches on one rear wheels caused when mounted. Approximately 200 miles on them. $1000. shipped or $850. picked up in NJ. 07003
Old Jan 30, 2017 | 01:19 PM
C2367's Avatar
C2367
M/T has 285X35/19' SS Drags that Is to be out in March or April, they have them listed on M/T web site. They fit the factory 10" wheel or a 9.5-11 inch wheel.
To Z51 drag set up
