JOC or Koni S/A shocks?
Old Feb 10, 2017 | 04:39 PM
chuckclanton's Avatar
chuckclanton
Default JOC or Koni S/A shocks?
So.....Decided to skip the Z51 or Bilstein HD shock options for
my base car. Already put Z51 sway bars on. Daily driver plus
autocross once a month in Las Vegas option. Any users of either?
Old Feb 12, 2017 | 07:31 PM
Mike Jesse's Avatar
Mike Jesse
I've installed the Z51 sway bars and rear shocks on my 17 base Stingray.
It still wallows around in the rear too much IMHO.
If I decide to keep it, I may spring for something more track oriented as far as the shocks.
For a daily though it's very nice.
Old Feb 13, 2017 | 08:11 AM
Roadrogue's Avatar
Roadrogue
I am debating the same thing. I suspect that nobody on this forum has used either on a C7.
Old Feb 13, 2017 | 10:06 AM
mustclime's Avatar
mustclime
your springs are to soft, your bushing are to soft as well. These need to up graded if you want less wallow in the turns.
Old Feb 14, 2017 | 01:11 PM
chuckclanton
CorvetteMod.com has the JOC set for $805(free shipping)
ShockWherhouse has the Koni Sports for $785(free shipping)
Old Feb 14, 2017 | 02:53 PM
Roadrogue's Avatar
Roadrogue
I have heard several times here that the spring rate is very similar between base and Z51.
I will get the firmer bushings if I get the Z51 sway bar package but I think I want to try a shock upgrade first. I'm ok with the body roll and steering feel but would like more sophisticated damping i.e. Less harsh at slow speed and more control and supple at higher on rough roads around here. That is what JOC shocks purport but don't know how Konis compare.
Old Feb 14, 2017 | 02:54 PM
Roadrogue's Avatar
Roadrogue
Flip a coin?
Old Feb 14, 2017 | 09:25 PM
Mike Jesse's Avatar
Mike Jesse
The Z51 bars come with urethane bushings.
Old Feb 15, 2017 | 09:40 AM
mustclime's Avatar
mustclime
I have heard several times here that the spring rate is very similar between base and Z51..
Z51 non mag ride rear spring is 165 n/mm. The base ray is 153 n/mm.......that's a lot, the 07 package uses 177 n/mm in the rear for reference. Chevy uses soft springs in the rear to make the ride feel softer, this where you get most of the feel of body roll since you are sitting with your back on the rear wheels.
Old Feb 15, 2017 | 11:05 AM
chuckclanton
So....The base rear springs rates are 873# and Z51 942#. I would
say that's not real soft! C6 is about 650# in the rear. Seems like
asking for a good ride and also controlling these springs is asking
too much!
Old Feb 16, 2017 | 10:29 AM
mustclime's Avatar
mustclime
too much!
you can not compare the c6 with the c7. Different mounting points mean different required spring rates. Ask the z06 and gs if their cars ride is to harsh.
Old Feb 16, 2017 | 06:42 PM
chuckclanton
Just had Bilstein HDs installed. Got the best of both worlds!
Old Feb 17, 2017 | 09:51 AM
mustclime's Avatar
mustclime
dampers do not hold up the car. The grip of the tires sets the spring rates, the spring rates set the dampers. Just putting parts on a car is not a good path IMO.
Old Feb 17, 2017 | 11:00 AM
chuckclanton
Sorry, still works great with the Z51 bars! Autocross next month will
verify one way or the other. I expect to stay with the C7 Z51s with
no problem. Yes shocks do matter. I trust Bilstein engineers over Chevy engineers to set the valving for their shocks.
Old Feb 17, 2017 | 02:44 PM
mustclime's Avatar
mustclime
pretty sure they are the same thing...hd=z51
Old Feb 17, 2017 | 04:52 PM
chuckclanton
You could be right. However they ride real nice as opposed to what I have
heard on the forum regarding the Z51s. Then again what I feel is a nice
ride may be rough to others.
To JOC or Koni S/A shocks?
