Full throttle back firing during upshift...?
2017 GS backfires during the upshift under full throttle.
Only happens in Sport or Track modes.
Is this "normal" due to the ignition cutting out for the upshift or should I have the dealer look at it...?
Thanx, Sarge
Thanx, Sarge
Mine doesn't fully backfire, but it does pop. That's normal. So the M7 holds the RPM while you row the gear, the automatic cuts fuel/spark/whatever briefly to allow the clutches to apply. Different approaches.
As Higgs will mention, manual drivers already normally lift during shifts...
Yes. Its a nice pop. Sounds cool.
Received 1,762 Likes
Mine doesn't fully backfire, but it does pop. That's normal. Manual doesn't shift fast enough to need this feature, but the manual features no-lift-shift. So the M7 holds the RPM while you row the gear, the automatic cuts fuel/spark/whatever briefly to allow the clutches to apply. Different approaches.
Received 2,379 Likes
it's not a backfire, it's spark cut for the modern clutched auto to shift properly.
a manual transmission wouldn't use this as the driver let's off the throttle and puts in the clutch when completing a shift thereby removing power application from the shift process.
You're spot on, except during no-lift-shifts, but that's different because there's no load on the transmissions when it's decoupled like that, whereas the automatic is still hydraulically coupled during shifts, so they need to limit rpm AND power.
