I wouldn't count on it being that easy! Some cars requires front fascia removal. Not sure on the Vette. How many miles? I believe the bulbs should be under the 3/36 warranty. Not a wear item.
Worth going by the dealer to see if in any stretch of reality they might change it under warranty. Worst case, you'll hear what they will charge you to do it and it might motivate you :-)
Anyone changed their headlight bulbs yet? One of mine went out. I saw the sticky, but I never understand the service manuals.
The headlight assembly looks to be in the fender. GM couldn't have made it that difficult to swap the bulbs. There must be an access panel.
Got to drop the nose, pop out the pod and THEN you can change the damn bulb. The C6 had an access panel in the wheel well and all you needed was to turn the wheel and tire out of the way and you could change the bulb. NFW in the C7!.
When I installed the Z06 grill and had the nose off, I changed both bulbs to 6,000K. No way in hell would I take the nose off to change a bulb and not change BOTH while I was in there.
Elmer
I would agree man. It is a small PITA to pull it off those clip are the 2 over on each side at the fender and bumper Robert
Elmer
just curious about going with 6k bulbs, color, brighter ?
Whiter. It's as white as you can go before you start going blue or purple. I had the 6Ks on my C6 and loved them so I switched to them when I did the grill.
D3S for 2014-
D1S for 2005-2013
Elmer
Reason: Added bulb designations
