Looking for A/C compressor delete pulley
Old Apr 18, 2017 | 07:32 AM
3X2's Avatar
3X2
Default Looking for A/C compressor delete pulley
Does any one make a compressor delete pulley? It would save me the time to remove the rear part of the compressor.
Old Apr 19, 2017 | 09:21 PM
BJ67's Avatar
BJ67
I have been studying the belt set up to see if there is any way to run the belt with out going near the a/c pulley. I have also noticed on the Camaro LT1 cars, they have the separate belt set up for the a/c so you can just slide it off.
Old Apr 20, 2017 | 02:37 PM
3X2's Avatar
3X2
Camaro mounts the generator where the Corvette has the compressor. Water pump spins opposite direction. Would require a Camaro water manifold and water pump. and lengthen the generator wiring. Inlet neck may not clear in a Corvette chassis. Also the crank pulley may not line up with the Camaro pieces.
Old Apr 20, 2017 | 04:23 PM
BJ67's Avatar
BJ67
Didn't realize the Camaro set up was that much different.
Old Apr 20, 2017 | 04:35 PM
3X2's Avatar
3X2
We have a 16 Camaro and I looked at it based on your thoughts. Thanks. It was a good idea I didn't think of.
Old Apr 20, 2017 | 04:51 PM
BJ67's Avatar
BJ67
Yeah, I was going to say you must have already researched the Camaro set up, you know way to much about it. I just happened to see the set up on a detailed picture, and of course knew nothing about it. If you come up with a working scenario, I really would like to know.
The LS motor set up on the C6,s you can slide the separate a/c belt off.
To Looking for A/C compressor delete pulley
