TSP offers CNC ported cylinder heads for the LT1. This service requires you to send in your existing LT1 heads For them to port them. Unfortunately they do not list the flow rates for this service on what the expected flow will be afterwards. Anyone know what the flow rates are?
They also offer replacement aftermarket PRC heads and notate on the site the flow rate for those but that is not the same as what I am asking.
Thanks in advance guys
Ant
mine moved 360cfm I believe at either .600 or .650 lift
Thats great to hear. Im planning to have them do my heads and have a call into them to get the numbers but the person there with the data is out right now.
Man that is moving some air on these heads. But also was told that these heads was so good that it was hard to improve on them any to what it would cost to have the work done. Robert
Texas speed was running a special.. they had just finished there CNC program! Factory heads flow around 300 (less then a stock Ls3 head) despite the 12 degree valve angle.. I think I paid less then a thousand and had them milled at the same time..
ls7 heads flow around 340-345 stock
I talked with Lonnie at TSP and he confirmed that at .650 they flow 358CFM. Those are some great numbers! That, coupled with the five angle valve job, and skimming the head (milling if your going NA) cost me less than a grand. They are even going to install my Vengeance Racing springs, retainers, and keepers and set the spring height for me! Woohoo! Im ecstatic! All I have to do is ship them my heads now.
Sounds about right!!!
I'm 12.1 CR at around 12lbs on stock bottom end lt1.. I run flex fuel and I'm decent at tuning lol
I don't think the stock heads are that good. If they were, the LT1 would have around 500 HP instead of 460 HP.
Stock LT1 heads flow....
.60 lift-----285 I/208 E
.65 lift-----291 I/210 E
but the ported LT1 heads from Texas Speed flow....
.60 lift-----345 I/226 E
.65 lift-----358 I/228 E
Stock LS3 heads flow....
.60 lift-----316 I/189 E
The PRC LS3 heads flow.....
.60 lift-----358 I/235 E
.65 lift-----366 I/240 E
As you can see the ported C6 LS3 heads flow better than the ported LT1 heads.
1. Did your intake runners have a small hole in them where they were ported out exposing the bottom of the rocker bolt hole/threads? Mine have a small pinhole area on each of the intake runners like this. I read online that using some simple thread sealer will take care of this, I'm just not sure if that is normal or not.
2. Did you get any bench flow test results for your heads back from them with your heads showing how they performed?
3. What did the porting job look like? Were all areas of the ports touched by the CNC machine? Mine appears to have several areas that were not touched by the machine, and that may just be because there's no restriction there. It doesn't look like the actual ports where the gaskets mate up are any bigger.
Ant
1) yes!! That's common!! Just use some "right stuff" or similar sealant
2)I did not!! Texas speed always has a solid cylinder head (especially for the money)
3) there CNC job doesn't touch everywhere... it would need to be touched up by hand if you wanted that!! I think the head could be improved a little, but for what you get it's solid!! They took the bare minimum bc they didn't want to increase
port volume too much.
