Injector problem
Old Apr 26, 2017 | 06:00 PM
Pastorrob1169's Avatar
Pastorrob1169
Cruising
Default Injector problem
Couple days ago my 2014 Base 42000 miles started missing and Check Engine Light Flashing, Traction Control Light, and Service Stability Control on screen. Took to trusted local mechanic. Codes say miss fire cylinder 7. Has spark and compression. He changed the injector, but codes will not clear and still misfires. Any ideas? I am told that possible ECM issues, but that would be very unlikely. Any help will be much appreciated.
Old Apr 26, 2017 | 09:44 PM
lakemg's Avatar
lakemg
Bad spark plug? Bad coil pack? Should be easy to swap plug and/or coil to another cylinder to see if the error code moves accordingly.
Old Apr 26, 2017 | 09:46 PM
lakemg's Avatar
lakemg
Forgot to also mention the actual plug wire as well...sometimes it's just the simple things
Old Apr 27, 2017 | 05:43 AM
Pastorrob1169
Cruising
He tried moving plug wires. Today he is going to check the wires from computer to injector. Also going to disconnect battery to see if that will reset computer.
Old Apr 27, 2017 | 09:46 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Try swapping coil packs and spark plug with different cylinder..
Old Apr 27, 2017 | 12:04 PM
Pastorrob1169
Cruising
Mechanic tried tried that as well. Possible ECM or wiring break?
Old Apr 27, 2017 | 12:19 PM
NSC5's Avatar
NSC5
Dumb question but when you say trusted local mechanic is this not at the dealership? Make sure he isn't looking at the wrong cylinder. 7 is the drivers side closest to the firewall.
Old Apr 27, 2017 | 03:25 PM
Pastorrob1169
Cruising
Yes he is looking at that cylinder. I live in the Florida Keys and closest dealer is over an hour away and a 300 dollar tow. Which I will now be doing. Hoping it was something simple worth not towing bill.
Old Apr 27, 2017 | 08:35 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Possible? Yes. Likely? Nah..
Old Apr 27, 2017 | 09:57 PM
Pastorrob1169
Cruising
Taking it to dealer next week. Atleast at this point whatever is wrong should be under warranty.
Old Apr 27, 2017 | 10:12 PM
lakemg's Avatar
lakemg
Please be sure to follow up and share what they find wrong with it so that others can learn potential cause for this issue.
Old Apr 28, 2017 | 07:17 AM
NSC5's Avatar
NSC5
Warranty should cover the towing (actually flatbed) to the nearest dealer.
Old Apr 28, 2017 | 10:26 PM
Pastorrob1169
Cruising
I will be sure and let you guys know what the problem was and how it was fixed. Already going through withdraw from not getting to drive my car. By the way I used to live right outside of Cincy.
Old Apr 29, 2017 | 10:34 PM
lakemg's Avatar
lakemg
Thanks! That's cool, what part of Cincy did you live in?
Old May 13, 2017 | 10:35 PM
Pastorrob1169
Cruising
They said it was a bad lifter and replaced the whole bank of lifters and push rods. After a two week stay at the dealer get it back and make it about two miles before it is running rough, backfiring and diminished power. So back to the dealer it went. Getting very frustrated at this point.
Old May 14, 2017 | 12:56 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
After three times your in Lemon Law territory. If they can't make it right this time, I'd start the paperwork for lemon law..
Old Jun 2, 2017 | 02:08 AM
golfdude49's Avatar
golfdude49
Cruising
Pastorrob1169. I too have a 2014 Corvette with the exact same problem, Miss fire, flashing engine light and traction light on. PLUS one more, I too am a Pastor.
Did you get the problem solved and what was it ?
Old Jun 2, 2017 | 08:13 AM
Higgs Boson's Avatar
Higgs Boson
bone stock or any mods?
Old Jul 1, 2018 | 07:49 PM
chaznad's Avatar
chaznad
Did anyone ever find out what happened here ? Same is happening with me .
I was told the culprit were injectors . Mine started blinking CEL and riding rough / service rear axle. Shut it down for about 20 and seemed fine after that . Nothing looks loose . I don't have a warranty as mine is tuned with only 30,000 miles
Any
To Injector problem
