M7
Old Jun 22, 2017 | 12:32 PM
Neil Baker's Avatar
Neil Baker
Default M7
Starting out in second gear is ok? Right??
Old Jun 22, 2017 | 12:38 PM
davepl's Avatar
davepl
It's a fairly big jump from 1st (2.29) to 2nd (1.61) but with a 3.42:1 rear end I can't imagine starting off with a 1.61:1 ratio is going to hurt anything. I can't say it's the hot ticket to clutch life, but I guess it's "OK".
If you smell clutch, then you know it's definitely not "OK".
Biggest risk is you have to slip it too much in getting the car going, and that could heat up the flywheel. But if it doesn't take a lot of slip to do it, party on.
Old Jun 22, 2017 | 01:37 PM
Bill Dearborn's Avatar
Bill Dearborn
Even starting in 4th isn't that bad. Both the LT1 and LT4 have sufficient torque that a lot of clutch slipping isn't required. Pretty easy to do with any Corvette made for decades maybe since 55 3 speed manual was introduced. Definitely not a challenge for any C4, C5, C6 or C7.
Bill
Old Jun 22, 2017 | 02:24 PM
Neil Baker's Avatar
Neil Baker
Actually I should have mentioned it is a Z51. First gear is 2.97, second is 2.07....
Old Jun 22, 2017 | 05:59 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
I do it now and then. No issues. But I do not have many miles on the car.
Old Jun 23, 2017 | 01:36 PM
VictorBarron's Avatar
VictorBarron
Except for wet roads, why?
To M7
