Throttle response
Old Jun 27, 2017 | 12:16 PM
Sarge9's Avatar
Sarge9
2nd Gear
Default Throttle response
Hey Guys,
i picked up my 2017 GS about 6 weeks ago and noticed that in neutral the throttle response isn't sharp and crisp as I would expect. Seems to hesitate a bit before climbing in revs. A couple of times it's also backfired.
Thoughts?
Much appreciated.
Old Jun 27, 2017 | 01:30 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Saving Corvette drivers from looking like fools by sitting still and revving the engine?
Old Jun 27, 2017 | 01:39 PM
davepl's Avatar
davepl
Backfired? Like flames coming out the intake somehow? That's a trip to the dealer on that one, I'm afraid.
If your car is an M7, the throttle response at tip-in is very lazy. This is arguably for mileage concerns or simply to make the car's power more manageable, but it appears to be an M7-only issue.
There is a product called the Vitesse throttle controller that does something along the lines of amplifying the low-voltage signals so that the ECM sees a faster "sweep" as you tip into the throttle.
It can also be remedied with a tune that changes the driver demand tables for the throttle, though that can void the warranty.
Old Jun 27, 2017 | 06:53 PM
97Black's Avatar
97Black
[QUOTE=Sarge9;1595029834]Hey Guys,
Thoughts?
Much appreciated
Get a Katech or Tony Mamo ported throttle body. That should take care of your throttle response.
Old Jun 27, 2017 | 07:25 PM
SFCTeach's Avatar
SFCTeach
[QUOTE=97Black;1595032417]
Originally Posted by Sarge9
Hey Guys,
Thoughts?
Much appreciated
I got the throttle body from Tony Mamo nice fix. I also have a '17 GS M7.
Old Jun 27, 2017 | 08:58 PM
VictorBarron's Avatar
VictorBarron
Vitesse.
Old Jun 29, 2017 | 12:24 PM
Sarge9's Avatar
Sarge9
2nd Gear
[QUOTE=SFCTeach;1595032638]
Thank you guys!
did you install the throttle body yourself? Sounds like it might be a nice touch.
Old Jun 29, 2017 | 03:04 PM
Ghostnotes's Avatar
Ghostnotes
I noticed this when i first got my 16 C7 and posted about it. 4th pulls better than 3rd sometimes as well and guess its related to the skip shift(which i disabled) and cam timing.
Do you know what tables are modified for the throttle response?
Old Jun 29, 2017 | 05:39 PM
Tony @ Mamo Motorsports's Avatar
Supporting Vendor
Originally Posted by SFCTeach
Thank you guys!
TB is a far better upgrade than the Vitesse which does nothing to actually improve the real performance of your engine. The TB will allow more air to be processed as well as cure your hesitation issues.....its worth 10-15 RWHP and RWTQ across the board. There are a bunch of threads going on related to this but here is the largest one
https://www.corvetteforum.com/forums...installed.html
Here are the gains.....the TB was swapped while the car was strapped on the dyno.....replaced with my ported unit and tested 15 mins later so ideal test conditions
PM or email me if you have any concerns or questions and/or would like to get on my pre-order list (currently a shortage of TB's at GM on the national level)
Regards,
Tony
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
Old Jun 29, 2017 | 05:49 PM
SFCTeach's Avatar
SFCTeach
[QUOTE=Sarge9;1595043916]
Thank you guys!
Yes I did it took about 15minutes, very easy!
To Throttle response
