DIY Alignment: Lessons Learned
Old Sep 22, 2020 | 04:09 PM
  #81
badhabit_wb's Avatar
badhabit_wb
Originally Posted by Prop Job
I meant to include this in my initial post but forgot. The adjustments with the AMT plates are too big to fine tune. My options now are accept the cross caster or start adjusting shims.
That's what I'm talking about. I took all uca shims out. Found the closest position with the AMT plates. Then used an equal number of shims on the uca to get the camber where I wanted it. I still ended up with a shim thickness that was less than one of the original washers if I remember correctly.
Old Sep 22, 2020 | 05:08 PM
  #82
Prop Job's Avatar
Prop Job
My camber is good, I'm trying to eliminate or minimize the 1.3 cross caster. I know an oem shim is good for about 0.5 deg of camber if removed from each of the UCA studs but how much caster is it good for if I only remove from front or rear pair of studs?
Old Sep 22, 2020 | 05:24 PM
  #83
badhabit_wb
I understand but any changes you make to the uca's, unless they are equal on both sides, will change your caster.
