DIY Alignment: Lessons Learned
Taking alignment measurements.
I had camber plates at position 2, but initial measurements showed -3+ camber. So, I ran all the plates to position 3 and installed roughly equivalent shims to equal stock on UCA. Roughly, I am averaging -2.0/-2.3 camber in the front, but I'm getting readings of +10.5 caster!
At a bit of a loss in the direction to head to bring Caster to +7.5. Ideas?
Based on my experience I believe the suspension geometry will fall to 7.5 if everything is even at the front and back of the victim arms.
The Hunter Aligner has Digital Cameras no lasers !!!!
Hell, i can't even find a place to mount tires without damaging my rims! I had winter tires mounted on base wheels at a tire shop near me, and they gouged the inside of the wheel.
I had track tires mounted at a "specialty" shop on a set of stock eBay wheels and they marred the wheel facings with their center post changer.
And, yesterday I found a great deal on ZP's at a local Firestone shop and they tore divets in the center of one of my Z51 black wheels. They called these scratches... chunks of aluminum are missing, scratches...... I get to deal with this today......
So, getting stuff done without damage in my part of the world is a joke.....therefore, I try to do it myself... At least if I screw something up, I take the responsibility! Sorry for turning this into a rant!
Bill
I will have to get some way to measure camber. I bought a Quick Trick set-up, liked the gauge, but very disappointed in the over all quality of the framing. My overzealous brother managed to scratch the hell out of one of my rims, when he jumped in to help...
I couldn't get the frame to stay on the wheel...it is useless and expensive.
Bill
https://static.summitracing.com/glob...nh-3300_us.pdf
I used this thread to figure out the angle for the turn plates:
http://specracer.com/forums/viewtopic.php?f=5&t=2504
I'm going to put my car on the alignment rack at TPC this weekend to check my work. I also want to check my thrust angle as I buggered that up when one of the toe link jam nuts came loose.
The rear caster also measured a little off from what I saw at home (0.6 laid back) with their measurements showing 0.5 and 0.9. I found this surprising given that we both were using the GM bracket and a digital level, but they did have a much better digital level with a remote display.
My toe was totally out of whack but I knew that after I had the issue with the rear toe link coming lose and me adjusting both sides throwing off the thrust angle. Mike and Marco got it squared away though.
I also noticed that they had a much easier time getting the suspension to settle on their rack after we lifted the car. I need to revisit how I'm using my slip plates and bouncing the car (they did it from underneath which I never thought of) to see if I can get the same effect.
Mike was actually a bit concerned about the fact that I shimmed one side of the UCA to get caster and also about the fact that I changed to toe links. We decided to measure the toe sweep with these changes and sure enough it was different. We weren't seeing the toe-in under compression that the stock setup has. That toe under compression is why DSC normally recommends a very slight 0.5 mm rear toe out at rest. Given this new information we decided to go to 1.0 mm of toe-in at the rear on my car.
It's amazing what a difference these little changes make. You could immediately tell on the street that the car put power down better than when I arrived. I'm hoping to get to the track soon to validate how the car feels at the limit.
Big thanks to Mike and the DSC crew. It's great to have the opportunity to learn from the best.
I made the changes to the front LCA as per Mark from AMT suggestions. Making my measurements, looks like I've idecreased my positive caster in the front by only 1 degree. I'm using SPS's Fastrax bubble gauge to take the readings. Caster is reading around +9.5 degrees now with camber -2.5 in the front. Camber plates at 2 in front LCA and 3 in rear position. Still roughly stock shims at UCA.
In the rear, I tried Poor-Sha's shimming on the rear UCA and am getting the .7 caster both sides.
