2017 C7 Z06 7MT 900 miles Check Engine Light - Code P0033 and P034
Good Evenig To All,
I have been on these forums for the last few years off and on. Finally decided to bite the bullet and purchase a Brand New C7 Z06.
I am coming from cars such as Porsche 911, Ferrari Cali 30 and Cali T, Maseratti, Bentley, All ///M cars (current generation and some previous).
I decided that it was time to finally buy American and never look back, I got very excited that I was going to get so much performance for so little money in comparison to the European competition. The Bonus for me was that it's American Made !!!
In any case, I am hoping that I can get some valid help and input from you guys.....
I carefully broke in the car and did the 500 mile 1st oil change as recommended. Finally decided that I can open her up a little, I mean this car is advertised as a beast and I figured I can open it a bit on the NJ Parkway should be fine.
at around 90 degrees in traffic before I even had a chance to open her up I got a Check engine light out of the blue with a message that read "Reduced Power"
I called Onstar and they did a remote diagnostic and said that it was coming back as code P0033 and P0034
It was a real disappointment to say the least. I brought it into my local dealer 2 days ago and it is still there. I have never had these type of issues with all of my previous cars. Either I was lucky or the Z06 just had some real problems.
dont get me wrong my other cars had issues but never something that would reduce my driving joy which is the main purpose of purchasing a car such as this....
do you you guys have any experience with these codes? Should I sell the car and take the hit now so I don't have to go through months of headaches or do you guys think this is something minor that should be resolved with this dealer visit?
are there any known TSBs ?
should I get a 2018 Z06 / any knowledge of the issue is resolved with the 2018s.
any and all expertise is highly apreciate it. Thank you in advance !!!
I'm Batman..
Pro Mechanic
Good Evenig To All,
P0034 - Supercharger bypass valve control circuit low
I don't have any experience with these codes, but that's what they bring up in HP Tuners..
djnice (08-01-2017)
Received 8,929 Likes
This is addressed in the factory service manual with a 2.5 page diagnostic procedure to go with it. It isn't a major failure of the engine. It could be caused by a bad fuse, a broken or shorted wire, an ECM failure or a bypass valve failure. That is why all new cars come with a warranty. Failures like this are more likely to happen when the car is new with low mileage. Not sure why the dealer mechanic didn't fix it right away unless they have to wait for parts and told you to take the car home while they get the parts.
Bill
Bill
Update:
Car was at the dealer all week. I was called this morning to come and pick it up and that it was ready. I got so excited to finally drive the car again.
The service adviser tells me that they had to flush out the cooling system and reset it. In addition the car was road tested for 3 miles with no issues.
I drive out of the Service department and the check engine light goes right back on with the "reduce power" again.
Should be an emberasment for the service department to keep the car for 1 week and not have anything resolved.
Left the car at the service department again and am very upset to say the least.
This will be attempt #2 to fix the issue. I really love the car and at this point contamplating really strongly to sell the car for a 2018 MY Z06 or just give up on the car all together and just go back to a 911 or an ///M-car.
Would prefer to give the Z06 one more run but don't want to deal with issues again.
And hate being without a car for so long. Keeping fingers crossed that try 2 gets resolution.
Does not not seem promising at this point. Will keep you guys updated. If anyone has any suggestions please keep them coming.
thabk you !
thabk you !
I am not sure I would trust this particular dealer if they really had the car for a full week and only flushed the cooling system. Also, you say you hate to be without a car. Didn't they give you a loaner? If they keep the car overnight the warranty includes providing a loaner car.
Yes, I would call them and ask what they are planning to do because you need the car tomorrow whether its fixed or not. Some dealers will just park the car in the yard and get to it a week later. Once you get the car back find a better dealer. Look up your warranty online and you will see they owe you a loaner car. Search the forum for you area or ask around to find a better dealer.
sounds like you are being treated like a push over. Go to a different dealer or put some heat under the service rep. Tell them what you learned from the codes on here and make sure you get a loaner vehicle every time, that way, they have incentive to get your car back to you ASAP otherwise the rental fees add up and can be tough for the dealer to explain to GM over a simple repair.
Update:
the service rep txt me that the Service tech ordered something called the "Supercharger Solenoid". Have any of you had any experience with this part.
please keep your comments coming. Thanks again !
There are other possible reasons for the DTCs set as Bill noted earlier but the solenoid is a very viable answer and hopefully the dealership actually found a fault with this part. Why they flushed the cooling system (either the supercharger aftercooler circuit or the main engine cooling system) makes no sense for the codes they pulled.
If possible in the future I would try a different dealer since your first experience wasn't acceptable. A decent dealer can make all of the difference. I have generally had good dealer experiences but both of my Cadillac dealer experiences (two different dealers) have been terrible. My 2008 CTS had a recall for the OnStar module and mine was a late 2008 model year production with Bluetooth capability but the first three times they replaced the module with the earlier non-BT version and each time claimed (and showed on the paperwork) that they had programmed and tested it for BT operation which is quite a feat of magic when the module didn't even support BT. My 2014 ATS was back 4 times in the first 500 miles to fix a simple emissions issue that resulted in a check engine light. Root cause was a broken vapor storage cannister and the CEL came from a failed purge valve (due to charcoal in the valve). They replaced two valves and then finally identified the broken cannister on the third visit where I also got a third valve but since they didn't properly flush the vacuum line between the valve and cannister trip number 4, valve number 4, and a new set of lines was necessary. A couple of trips would have been reasonable but 4 was just stupidity on the part of the service tech.
Bill
Update:
thabk you !
thabk you !
Bill
I swear I have paper work that says a car is provided, but your right it might be dealer specific paper work.
