Cabin Fan failure
Old Aug 19, 2017 | 03:16 PM
bikevette's Avatar
bikevette
Default Cabin Fan failure
OK, driving home from a track day yesterday at the Ridge Motorsports Park, I started the car to leave the paddock and cranked up the AC, and the cabin fan wouldn't come on. I could hear the AC compressor kicking on, but no cabin fan. Tried everything including playing around with recirculation button, sync, changing temperatures, trying to use heat, changing air outlets, different fan speeds, etc. Had to drive home on a hot day with windows open.
I don't run AC when on the track, only the fan.
Got home and pulled the number 17 and number 6 fuses from the engine block fuse box. (See manual for fuse locations.) Fuses were fine. Put them back in and the cabin fan starting working fine again.
Hmmmmmmm??!!
It's intermittent. Sometimes works, sometimes doesn't.
