Correct oil pressure?
Old Aug 21, 2017 | 10:19 PM
highcountrybumpkin's Avatar
highcountrybumpkin
6th Gear
Default Correct oil pressure?
I have a 2016 Coupe, non Z51 engine. My car has less the 3000 miles, runs fine, no issues but a bit concerned over oil pressure. According to the dash gage, it runs between 30 and 35 lbs, never higher. Previous Vets and other cars have always run close to 40. Any thoughts.
Old Aug 21, 2017 | 11:00 PM
spearfish25's Avatar
spearfish25
I think it's fine. You have a variable oil pump that will change pressure as demanded by RPM. High 20s to low 30s is normal at idle when warm.
Old Aug 22, 2017 | 12:47 AM
767guy's Avatar
767guy
Normal
Old Aug 22, 2017 | 08:33 AM
NSC5's Avatar
NSC5
It is normal. Watch closely for the first few miles after a cold start and you will probably see it making several very brief excursions above 40 PSI as it goes through a self test of the dual displacement oil pump control system. Once it is warmed up try some high throttle acceleration with the engine in the upper RPM range and you should see the pressure ramp up above 40 PSI as more pressure is developed to feed the mains and operate the oil "jets" that spray oil to cool the piston bowls.
Old Aug 22, 2017 | 12:13 PM
highcountrybumpkin
6th Gear
Old Aug 22, 2017 | 12:14 PM
highcountrybumpkin
6th Gear
Old Aug 22, 2017 | 12:32 PM
robert miller's Avatar
robert miller
Default ttt
Man you are good at that pressure in the car. non z51 and the z06 all are running this same... Robert
Old Aug 22, 2017 | 08:43 PM
highcountrybumpkin
6th Gear
To Correct oil pressure?
