Data logging App
Old Oct 3, 2017 | 05:13 PM
BlueDevilZ51's Avatar
BlueDevilZ51
Default Data logging App
Any suggestions on what App for a droid are good for data logging the C7? Also what cable would you suggest?
Old Oct 4, 2017 | 10:11 AM
IM4A2Z's Avatar
IM4A2Z
What are you wanting to data log (PID's)? Get a good bluetooth OBDII device and then buy Torque Pro from the Google Play Store
Old Oct 4, 2017 | 11:22 AM
BlueDevilZ51
I'm just looking to see my AFR and if I'm getting any KCs. I have a 93 octane tune from Edelbrock with their stage 2 E Force supercharger. It runs great , im looking to add a Tony Mamo Throttle body, i just want to make sure im not to lean.
Old Oct 4, 2017 | 01:27 PM
IM4A2Z's Avatar
IM4A2Z
In order to accurately log AFR you will need Wide Band O2 sensors. The stock narrow band O2's only work at partial throttle not Wide Open Throttle (WOT). In WOT the ECU commands fuel based on RPM, IAT, MAP all calculated via the tables programed in the ECU.
Old Oct 4, 2017 | 02:15 PM
BlueDevilZ51
I didnt know the car only had a narrow band o2, was hoping it had a wide band. You seen like you are knowledgeable with the C7 ECU. I was wordering if the ECU would self learn or adjust if its a little lean after I install a ported throttle body?
If so would i be better off disconnecting the battery terminal for a few mins or just take it for a drive for a few miles and WOT pulls?
The car is stock besides the Edelbrock Supercharger and tune. Thanks
Old Oct 4, 2017 | 04:45 PM
IM4A2Z's Avatar
IM4A2Z
None of the manufactures, foreign or domestic, use wide band O2's.
To answer your question; At idle and cruise (partial throttle) the stock ECU will use the O2's to adjust short term and long term fuel trims in order to reach target AFR. This is called closed loop.
Since your car is not stock and has a custom tune then I would ask your tuner how the tune is setup. Some will side step the self learning/adjusting, not a bad thing necessarily, by locking in values.
Old Oct 4, 2017 | 06:21 PM
BlueDevilZ51
Got it, thanks for explaining that.
Old Oct 4, 2017 | 08:52 PM
IM4A2Z's Avatar
IM4A2Z
Torque Pro is good for keeping an eye on things in general but, if you want to get serious then check out Innovate Motorsports if you want to follow through with data logging and wide band O2 sensors. I've had good experience over the years using their products on my cars and motorcycles.
Old Feb 5, 2019 | 07:33 AM
427C62013A's Avatar
427C62013A
Anyone use the BlueDriver Bluetooth OBDII Scan Tool for iPhone, iPad & Android? This has data logging features to export to excel.
Old Feb 7, 2019 | 12:36 PM
snampro's Avatar
snampro
Would like to know this, too. What OBD II bluetooth device do you use?
Old Feb 7, 2019 | 12:56 PM
Mike@DiabloSport's Avatar
Mike@DiabloSport
Supporting Vendor
Old post, but, this is not quite the case.
Ford has used Widebands in the Mustang since 2011, and most of the Ecoboosts use them as well.
Dodge uses Widebands in the Hellcat/Demon as well.
Several import models use them as well, especially Euro stuff.
Old Feb 19, 2019 | 10:53 AM
427C62013A's Avatar
427C62013A
I have been using the BlueDriver Bluetooth OBDII Scan Tool for a couple weeks now and it works great with the iPhone or iPad Apps You can monitor several parameters at once and create log files. The software recommends no more than five parameters at a time but there is nothing stopping you from adding more. It takes a snapshot every half second or so with 4 or 5 parameters selected.
You can use your ipad/phone as a display for gauges, time charts, or just a digital readout, while driving.
It allows you to clear any trouble codes or perform a smog check as well.
Old Feb 19, 2019 | 10:58 AM
snampro's Avatar
snampro
Yup, same here, bought the BlueDriver and am happy. I've used it in my Z06, my wife's Stinger, and my kid-hauler/tow vehicle Sequoia. Very cool, works great!
Old Feb 21, 2019 | 03:37 PM
Red86Cfour's Avatar
Red86Cfour
Can it get monitors to start?
Old Feb 22, 2019 | 08:48 AM
snampro's Avatar
snampro
Been playing with the bluedriver and their software for awhile, works great.
I thought I'd try Torque Pro because of the display options and I cannot get it to work with my bluedriver scan tool. Anyone have that problem?
Figured it out: Bluedriver only works with their app. I'll be returning it and buying a new one...
DO NOT BUY BLUEDRIVER IF YOU WANT TO USE ANY OTHER APP...
https://torque-bhp.com/forums/?wpforumaction=viewtopic&t=9534.0
To Data logging App
