LT4 best Cold Air Intake system?
Halltech Stinger +60 HP
AFE Black Series +46 HP
And I can't wait to see the upcoming VaraRam!
Which one is the best? Do you know other products? The HP increase declared is reliable?
Here is a link to info on our C7 unit
Call me at 713-477-8100 with any questions or to order!
VR tech
Today, the GM and especially the Corvette engineers are doing yeoman's work on producing great HP from their engines and keeping them together with a warranty. Can they be made to produce more HP, you bet, until you run into the add on warranty issue(s). They're somewhat underrated and over engineered to keep them 'together'.
Right now, and w/o voiding the warranty, the only way to "push the envelope" is on the exhaust side. That bi-modal muffler is a real impediment (check out a cutaway of it) especially on a blown (pardon the pun) engine. Remember too, if an add on requires a "TUNE", it will void your warranty. My $.02!
Our plan is to get some different year Z-06's in our facility to test this week and next.
Once we have run our tests on them , I will be able to answer the time line question.
VR tech
We showed part of this with the 2010-2011 LS-3 Camaro ram Air system and that info is on the Camaro page on our site. We did it to show people what ram air is all about. An air temp reading from over in a fender means nothing if that same temp isn't being realized inside the plenum of the manifold.
People tend to get obsessed with pressure not realizing that the point of any ram air system is first and foremost, to intercool the intake manifolds plenum. This area will be 20-60 deg hotter than ambient temp on most V-8 engines. The map pressure sensor can be off due to its placement or its sensitivity and can effect what you see in a data log. The consensus at the SAE is that ram air is worth about a 4% power increase even if there is "ZERO" pressure rise.It's from cooling the plenums air so that the runners are drawing ambient temperature. Most OEM engines hover around 40deg above ambient inside their plenums. A guy might say ,but what if I dyno it stone cold ? well that's not realistic and all 4 cycle engines suffer from pressure reversion and "spit back". That would be left over hot exhaust gases from the firing cycle that didn't go down the exhaust port combined with air bouncing off the intake valve . This travels up the intake runner and into the plenum when the intake valve opens as pressures equalize. OK, Back to Ram Air , If you have a Ram Tuned manifold like an LS-1,2or 3 that generates 1.5-2psi of boost at the torque peak ,the gains will be exponential. All of our street systems are "Well Over" 100% at the back of the TB.
The challenge with a "Cold Air system" is to generate enough velocity from vacuum and an efficient design to force feed the cylinder head/intake manifold combination. The C-7 LT-1 system does this at specific RPM points BUT the LT-4 represents a much higher flow volume than the LT-1. The LT-4 has been designed to support up to 1000 Rear Wheel HP. Even though most will never go there, some will. Most will be bolt on stock cars and that's fine , but we want to make sure the system is setup for the bigger guns if the need arises.
Our goal is to bring our customers as much efficiency and consistency as possible to the LT-4 combination. That way your Z-06 runs the same all of the time, not just when its cold outside.
VR Tech
VR Tech
You are right, that the supercharger heats the air moving thorugh it and you are also right that a cold air intake does nothing to cool the air leaving the intercooler.
However, what a cold air intake possibly does is to feed the supercharger with cooler air.
If it does that, the air leaving the supercharger is cooler compared to the air without the cold air intake.
The air then enters the intercooler with a lower temp and in the end enzers the cylinders cooler.
Regards
Götz
Götz
The bus has left the station a long time ago! The Cai's work great on the Z06 which comes with a restrictive filter that is also on the 460hp Lt1.
Just a filter swap is 30 rwhp and the full Cai like the Halltech is about 50
these are numbers for the M7 A8 is a little less.
You trying to restate the facts is for entertainment purposes only.
I'm not trying to start a war on this matter, it's not worth it to me but I hate to see people spend a whole lot of money needlessly for a couple of ponies (maybe) on CAI's for this application. For normally aspirated engines it might help minimally.
The real issue with a screw charger isn't the heat from the compression of air to create boost. The real problem is that your Rotors TOUCH, they are seated . That is where most of the noise comes from. There is a dry lube coating that wears off over time. That is why GM reps don't like to see catch cans on the LT-4 engines. The PCV system and all of that puking oil into the blower is an additional lubricant for the rotors. Now as for the water changers, we have measured their effectiveness already and I can say that GM could have done a better job in this area. All they really did is create a power unit and burry it into the V of an engine. The, incorporate as much as possible into one, casting style construction holds far to much heat. Making things compact is typical OEM, but has drawbacks. Cooling is one of them.
I cannot tell you everything about the LT-4 system until its release.
I can say that LT-4 owners will be very pleased with the results, from the power generated to the consistency in how their cars run. Tuners will love it because they will be able to do things they could never even think of doing before to make more power.
VR tech
This is what I tell every Racing team and OEM I have ever done work for.
Putting up a Dyno number is great. Its not so great ,if when it matters the most, on the road or track , it pulls timing and detunes the car. ( In their case, blows an engine)
It needs to at least Keep the power it makes rather than throw it away from poor Dynamic Efficiency. Sometimes its about keeping what you have , not necessarily generating more power.
VR tech
