Engine removal
Old Nov 4, 2017 | 12:09 PM
Ghostnotes's Avatar
Ghostnotes
Default Engine removal
Getting ready to do cam, dod delete, springs and billet bottom end. Will be doing this in my garage. I think I remember seeing a write-up on how to remove the engine from the top. I did not see it in the how to section though.
And also I will be using a floor jack and jackstands to get it high enough for under access. Where will i be putting the floor jack, front/rear and where will be the best point for the jackstands?
Thanks!!
Old Nov 4, 2017 | 02:43 PM
davepl's Avatar
davepl
Read the Helm shop manual. Read the whole engine removal section BEFORE you turn a single nut, at least skim it.
If you're attempting this without a manual and hoping you'll get detailed enough information on a forum to R&R a modern engine, I can only say "Buy the manual". That'd be some wild false economy, they're only about $300 I think.
Old Nov 4, 2017 | 02:44 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Im the guy you're looking for.. lol
Go to my profile and look at my first visitor message. It will show you how to see all my How To guides..
Ant
Old Nov 4, 2017 | 02:46 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Not quite accurate. I've done many How To's for the C7 with very detailed info and pictures from the service manual when necessary..
Old Nov 4, 2017 | 03:30 PM
Ghostnotes's Avatar
Ghostnotes
Thanks!
Im no novice to engine work and could work my way through it. But admittedly, it will save a lot of time instead of having to learn what has to be reomved or taken out of the way as i go. And i thank you in advance.
If i was not doing the bottom end, it looks like just a regular DOD cam swap could be done in car pretty easily. I just read about a fabbed up cross brace so you can lower the cradle just enough to remove the pan for the chain removal. On my LS motors i just loosened the lower mount strut and put spacers in.....can this be done with the C7 as well?
Old Nov 4, 2017 | 04:09 PM
Ghostnotes's Avatar
Ghostnotes
For some reason i do not see it.
Old Nov 4, 2017 | 04:51 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
From my profile page:
Looking for my "How To" guides? Do an advanced search and fill out your search like the below image to find them all!
Old Nov 4, 2017 | 07:31 PM
Ghostnotes's Avatar
Ghostnotes
Found it!
Thanks!
Doesn't seem too bad. Little more than my G8. Cold have that out in about 2 hours after the second time.
Did GM make the harness connections sectional for a cradle drop? Or would you still have to take them completely off the block?
Old Nov 4, 2017 | 07:59 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Found it!
Thanks!
It's all one harness, and not sectional. Unfortunately there's no way around it.
Old Nov 5, 2017 | 12:32 PM
davepl's Avatar
davepl
I'm not saying anything is impossible. Anything is possible, more or less.
I'm saying removing the engine from an $80,000 car while saving $300 on the detailed instructions on how to actually do it is false economy.
I'd still refer to the How To guides here as well for the perspective of people who've actually done it, of course.
I stand by that assertion.
Old Aug 13, 2020 | 07:43 PM
Bigmo1's Avatar
Bigmo1
2nd Gear
Im sorta in the same mind set. I want to cam the car, but with only 1600 miles on the car im very uneasy. I have always done my own work, built many fast cars and Harleys...but this is different. I think im more concerned with messing up the paint on the car. No matter how much you think you are protecting the car, you manage to scratch or hit something. With $75 grand at stake.....hmmm
Old Aug 13, 2020 | 09:45 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I don’t even use fender protectors when I work on my C7. I’ve pulled the motor in and out almost a dozen times and have disassembled 97% of the whole damn car too lol. I guess I’m just careful lol
Old Aug 14, 2020 | 07:37 AM
Ghostnotes's Avatar
Ghostnotes
Same here.
There is plenty of room to pull it out of the top. It's not that bad. A few transmission bolts are the hardest part. Just purchase an engine leveler and it will be fine. I only had my car 3 weeks before the engine came out. On #3 now. One thing to save hardship i did the second time was to cut my exhaust manifolds right below the flange with a reciprocating saw since headers were going to be used.
Old Aug 14, 2020 | 10:23 PM
badhabit_wb's Avatar
badhabit_wb
I have to agree with FYREANT he's done a lot of how to's and he's helped out with questions others have had, me for one, on things that he hasn't written how to's on. His instructions are better than the factory manuals and I have them.
Old Aug 15, 2020 | 10:43 AM
Zjoe6's Avatar
Zjoe6
Just looked at FYREANT'S engine removal how-to yesterday. Very well done and a major contribution to the forum.
Old Aug 15, 2020 | 05:01 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
well I wouldn’t say they are better than the manuals, but at least my pics are in color! 🤣 Thank you for the support brother!
Thanks man, I’m just tryin to pull my weight around here lol
Old Aug 15, 2020 | 05:18 PM
badhabit_wb
I don't give compliment out easily and certainly not if they're not deserved. I appreciate your work brother.
To Engine removal
Old Aug 20, 2020 | 07:46 PM
Chazzmania's Avatar
Chazzmania
Can't go wrong using FYREANT'S notes I have looked at a couple things he posted along with his A&A install, motivated me enough to install my kit and my car hasn't blown up yet lol.
Old Aug 21, 2020 | 04:32 PM
T/A KID's Avatar
T/A KID
Used Ants stuff many times!! Great info
Old Aug 24, 2020 | 10:47 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Thank you both! We have such a great community of people here!
Ant
