Cluck/tuck noise when engaging first gear idle
Not sure if I posted on the right place. Ever since I bought my c7 7mt I’ve noticed that sometimes when fully stopped. As I’m engaging first gear ( clutch pedal all the way down moving shifter into first) I get a wierd sound that I can only describe as a “cluck” noise. This also comes with quick light forward movement while stop on a light. It dosent happens all the time. I can also sometimes hear the cluck/tuck noise when shifting to third.
Anyone experience this? I’ve driven mt for over 10 years never heard experience this.
Did you buy it new? It's possible it was serviced and not properly bled, but it isn't something I have read about as a common problem.
I would investigate clutch disengagement. Is there something under the pedal? Does the fluid in the slave look right? My stock 17 doesn't do that so it should work unless something is just broken, it probably has a warranty so I would make it Chevy's problem beyond the simple stuff. Good Luck!
While intermittent, it has become more frequent as it happened again this morning and twice last week, and a couple times over the past couple months. I spoke to dealer again last week and still nothing they will do to investigate under warranty until it finally breaks enough they can reproduce it. So their advice was to drive it until it finally breaks down. Which is a crappy approach to what is supposed to be Chevrolet's flagship product. but it is what it is.
My question is has anyone had the 'groan/moan' finally diagnosed?
