Wheel recommendations for track wheel and tire setup
I have a 16 Z06 and i am looking for a track 18 inch set of wheels and tires. I have a extra set of factory z06 wheels with cup tires on them now that I have been using but I would like to try some 18s to see how they work. Also to save a little on buying tires for the 18s. Ones anyone have any experience with doing this?
archfarseer (02-27-2018)
Received 8,961 Likes
No problem fitting 18 inch wheels over Ceramic Brakes. I have a set of CCW wheels that I ran on my C6Z that I have been running on my C7Z06/Z07. They are 18x11 in the front and 18x13 in the rear. The 18x13s are just a little wide for both the C6Z and the C7Z. When the car is off the ground the 18x13 wheels will touch the rear upper control arm and can not be torqued tightly until the suspension is depressed a few inches. I run a .2 inch spacer between the wheel and the rear hub and don't have any problems with the wheels contacting anything while on track. They might hit if the car went airborne but I haven't driven on a track that has taken me airborne.
The front Ceramic rotors have a depressed area in the center of the rotor hat which the CCW wheel doesn't fit into properly. The CCW wheel hub face is slightly larger in diameter than the stock wheel (a few thousandths) so rides on the radiused edge of the depressed area which means it can't mount solidly to the rotor. CCW provides a special spacer that fills that depressed area and provides a flat surface for the CCW to mount against. This is true of the C6 Z06/Z07 and C6 ZR1 brakes as well. Certain Wilwood rotor hats have similar depressed areas and that is how I found out about the mismatch after I lost a front wheel off my C6Z at VIR two years ago.
I use Extended Thread lug nuts that I purchased from CCW (I think they are Gorilla's but am not sure since they come without any markings). The extended threads on the lug nuts go inside the lug holes in the wheels and provide an extra .3 inch of thread engagement.
If you purchase other brand wheels you have a good chance of not needing the front spacers. I know that people have purchased Forgelines and didn't need the front spacer with the ceramic brake.
The 18x11/18x13 wheel size was the hot setup on the C6Zs from the time they were first introduced. They permit you to run 315/30/18 front tires and 345/35/18 rear tires. The tire diameters are close to stock and do not screw up the electronic systems.
I have also run an 18x12 wheel in the rear since I started using the Pirelli PZero Slick scrub tires. They come in a 325/660/18 size and the 13 inch wheel is just a little too wide for the 325 tire. The combination will work and work well as I got a personal best lap time of 2:05.81 at the Glen this year but the tires look like a size 40 chest suit fitted onto a guy that has a size 44 chest. I dropped down to the 18x12 wheel and subsequently achieved a personal best lap time of 2:04:89 at VIR.
Bill
Bill
ilkSurfer (07-29-2018)
Bill
Bill
Have you used Hoosiers and have any opinion compared to the pirielli?
Track tires
Bill
Bill
I have another thread going on this topic and your information is great addition. I have some Pirelli P Zero 305/315/325-18 scrubs in my garage now, saving up money to get some Forgelines to put them on for next season and others have confirmed they fit over the CCBs I have.
Question: I also thought about trying some Hoosier 315/345-18 R7s. Online info says the 345 tire should work on a 12" rim. Do you have a suggestion there? Forgeline also has a 12.5" rim size, would that work with the Pirelli 325?
I am trying to get by with just 4 new wheels, not 6. Those things are not cheap.
thanks, paul
I have used Hoosier A7s and R7s along with the Pirelli's. I think they are all pretty much comparable in performance to the Micheline PS Cup2s. I purchased one set of used Pirelli's this year and ran them for 8 days and put close to a thousand track miles on them. 500 at the Glen and 500 at VIR. I have run new and used Hoosiers for quite a few days as well. One new set of R7s went through 8 track days before they started losing grip and one of the front tires wore out on the edge. The Cup2s run fast but don't last as long. I got about 2.5 days out of a set of Cup2s before one of the rear tires delaminated.
If you do a lot of track days the used DOTR Hoosiers and/or Pirelli P Zero slicks are really cost effective compared to the Cup tires.
Bill
St. Jude Donor '14
I bought CCW TS12’s. 18”X11” with 315/30/18 up front, and 18”X13” with 345/35/18 in the rear. I’m running R7 slicks. Love them!
nicktenn (02-22-2018)
18/11 and 18x12.5. Knurled so the tire spins less on the rim.
https://www.signaturewheel.com/product-page/sv501
Supporting Vendor
Guys we have a special on all Track Sets from Forgeline, call or Text 440-915-6166.
All our track sets are Track and Load rated for usage. Please note alot of other manufacturers are selling cheap wheels and guys are using them on track but due to the stresses tracking puts on the car and wheels its imperative that load rated track wheels be utilized. For the occassional lap it wont matter but for those guys pushing it hard there are not many manufacturers out there that have Track Rated wheels and its a reason we sell Forgeline for all our Z06s on the track.
PLEASE NOTE IF THEY ARE TRULY TRACK RATED AND APPROVED THERE WILL BE A LOAD RATING STAMPED ON THE WHEELS, MAKE SURE YOUR RACING WHEELS HAVE A LOAD RATING STAMPED, IF NOT THEN THEY ARE NOT RATED FOR TRACK USAGE!!
And YES if you want Knurled Wheels we have that option as well. I cannot Stress again the importance of the correct wheels on Track, I as well as everyone want to save money and not spend alot for Track Wheels but I can assure you the cheaper options out there from third party Manufacturers do not hold up to the Tolerances needed for track and only a matter of time before issues occur.
WELD, CCW, FORGELINE,HRE, yes all make great track wheels just make sure before you see a cool wheel that seems thousands less and is so called forged made for Track that it is indeed rated for such usage, I see lots of Forum Members using wheels that are not made for the track to save a dollar and it worries us. We dont carry every track wheel for the Vette but any wheel we sell for Track Usage is FULLY WARRANTIED ON TRACK
__________________
#1 Forged Wheel Master Distributor for Corvettes Worldwide since 2010
Call/Text 440-915-6166
Forgeline*Anrky*HRE*PUR*Brixton*Vorstein er*Akra*Brembo*IPE and Many More....
REVIEWS: http://forums.corvetteforum.com/whee...r-reviews.html
WEBSITE: www.cw4L.com
EMAIL: sales@cw4L.com
PHONE 440-915-6166 CALL OR TEXT ANYTIME!!!
Follow us on Instagram @custom_wheels_for_less
