Do you have an order receipt for the tire pressure sensors with the GM part #'s on it??
The part #'s for C7 sensors are 13581560 or 13598775. Either one will work in all C7's.
Maybe they sent you the wrong sensors.
The rear wheels worked from day one. Same sensors went in the fronts. I can't find the receipts right now. The car ended up learning the sensors I have no idea why it took so long though.
Originally Posted by DAVE396LT1
This sounds like it's being overcomplicated:
1) Install new wheels
2) Go watch Seinfeld for 20 minutes
3) Car is ready
No driving required. Worked for me every time. I'm not 100% certain that Seinfeld is required, but the 20 minutes are.
I have not seen driving as being part of the instructions, so for all I know that's the problem!
Yeah, after the 20 minutes of being stationary, then you drive it.
"WHEN A TIRE IS INSTALLED, THE VEHICLE MUST BE STATIONARY FOR ABOUT 20 MINUTES"
- Page 10-60
Well, not sure what the issue was, but the car sat overnight and I drove 3hrs to the track, and 3hrs back without the car learning the sensors for some reason. Eventually they did learn... just unsure why it took so long.
