AFM Shudder Bye Bye!
As a C2 guy, my new 2017 Grand Sport is a delight. Learning all the major and minor differences 50 years can have on a car. Noticed that there was a shudder that would wave through the car. Mostly felt it through the seat. Checked in with the forum and the two threads were the AFM or torque converter (circa 2015-2016). I noticed that the shudder only occurred when in automatic mode and was not speed dependent. When I would put the car in manual and paddle-shift, the shudder disappeared. A little bit of research and I found Range Technology AFM disabler (Range). It arrived and it was a 5 second plugin to the ORB ll and the shudder was gone. Even though the high speed shudder was mainly what I was trying to get rid of, it was surprisingly smoother and quieter at the low end as well. Very happy camper.
Why AFM at All?
Speculating, GM probably needs to put AFM on all their V8's and V6's to up their overall EPA mileage rating. Makes sense to put it on for that, but a bit crazy for a Vette. As an engineer, I would have disabled the AFM when Sport or Track mode was selected. Again, my guess, is that doing that may have been an EPA problem....
Questionable GM Dealer
I was due for an oil change and took the car into the dealer where I bought it. Mentioned the shudder in passing and the service advisor called me back to his office to tell me that it needed a new torque converter. This guy was 100% FUD (fear uncertainty and doubt). In a retirement community, I suspect they prey on older people...especially when under warranty. I told him I was familiar with the torque converter problem on the 2015-2016, but was told by Corvette engineers that it was a faulty supplier and the corrected the problem in late 2016. Needless-to-say, I hoofed out of there. His parting words were, "God forbid you have a problem." I told him that is what tow trucks are for and that God was too busy to worry about my Vette.
Warranty?
Range tech support and my "new" GM dealer said there is no warranty issues because it is a plugin and does not modify the firmware. It merely cuts off the AFM leaving the car in V8 mode all the time like Duntov intended.
Just Reporting
Hope this helps other experiencing the same weird shudder. If you are experiencing a shudder, put it in manual in 8th gear. The shudder should disappear. If not, there is something else going on.
Hope this helps!
Bob
Looking forward to hearing what you think. My difference was remarkable.
Bob
AFM is bad enough but the abuse of the torque converter lockup clutch in an attempt to reduce vibration should go in the engineering stupid hall of fame.
Bob
- Range Technology Website
- Range Technology on Amazon
- Other (unauthorized) Amazon seller
- Ebay (unauthorized) seller
- AutoAnything (AUTHORIZED DEALER)
- Other AUTHORIZED DEALER (see our website for more details)
- Gift (unknown)
- Other/UNKNOWN
One thing is for sure, if you get it from Range, they will send you the latest version. Other vendors, it is whatever is on their shelf.
Bob
Bob
My Range Disabler worked for a few days and then I had a weird experience that now is duplicating regularly.
One day a fired the car with the Range Disabler in the slot. The engine sounded funny and when I put it into drive, it went into 4th and stayed there. Tried to manually shift and it would not. Check Engine light came on. Pulled the Range Disabler out and restarted. Went into gear normally and after a few miles the check engine light went out. ...but of course, the shudder came back.
What I know is that if I put the Range Disabler in after running the car without, it works perfectly. Next time I start, it goes into the 4th gear error. Must have tried ten times and it always follows the work, then no work error.
I contacted Range tech support describing the problem, but have not heard back.
Has anyone had any similar experience?
Has anyone tried the DiabloSport Disabler?
Moreover, has anyone found that a Vette dealer can fix the shudder with a firmware update?
Thanks for help and thoughts.
BTW, I used my OBD2 unit and software to clear all the error codes. Did not help.
