TPMS for 2018 Corvettes
Old Dec 28, 2017 | 01:33 PM
CADbrian's Avatar
CADbrian
Default TPMS for 2018 Corvettes
In the spirit of sharing information I've learned, I've copied and pasted the information below to help others that might also be looking for tire pressure sensors for 2018 Grand Sport:
Original message from me sent to GM parts vendor:
"I was referred to your listing by a member on the Corvette Forum. When I check compatibility by inputting my vehicle into the drop down menus I get the following message:
This part is not compatible with 2018 Chevrolet Corvette Grand Sport Coupe 2-Door 6.2L 6162CC 376Cu. In. V8 GAS OHV Naturally Aspirated.
Can you please tell me one way or another if this item is compatible with my car and if not can you please provide me with the TPMS part number I need as well as a link to your listing if you sell that part? Thanks."
Response from GM parts vendor:
" In 2018 they changed a few things up their is actually 3 choices. The part # you need is 13348393 They are 433 MHZ, and the New design."
This part number [13348393] was just confirmed by a local Chevy/GM dealer as being the correct part number for 2018 models.
Please keep in mind that I do not know if this part number is specific only to the Grand Sport model (kinda doubt it), or if it is applicable to all 2018 Corvettes. Nevertheless, this info should become more helpful as time goes on as more people need TPMS sensors for their 2018 Corvettes.
Old Dec 28, 2017 | 01:46 PM
BEZ06's Avatar
BEZ06
Thank for the info!!
That's interesting. The 2014-2017 sensors all transmit on 433MHz as well, so I wonder if those sensors with the new part# will work in the earlier C7's or not?!?!
They already changed the part# once, and the sensors with both older part#'s work in 2014-2017 cars, so it will be interesting to find out if anything has really changed other than the part#.
Old Dec 28, 2017 | 02:02 PM
CADbrian's Avatar
CADbrian
Agreed.
Old Dec 29, 2017 | 12:31 PM
CADbrian's Avatar
CADbrian
The information above is simply what I was provided by others, and since that information was given to me by other humans (who have the potential to be wrong) it's entirely possible (since I haven't gotten the parts and successfully installed them yet) that I was given incorrect information. So, if you learn that the information above is incorrect (or is indeed correct) please share your experience/knowledge here. Thanks.
Also, after my tires and wheels comes in (and get them mounted) I will share my experience(s) here to let you know if the information above is correct or incorrect.
Old Dec 29, 2017 | 01:50 PM
gtam85's Avatar
gtam85
I have a 2018 GS and bought an extra set of TPMS from House of Wheels. The part numbers were 13581560 (p/n that worked with pre-2018 models) and they synced up easily. Mounted them on new wheels/tires, and they communicated fine. No need to relearn or calibrate.
Old Dec 29, 2017 | 06:46 PM
BEZ06's Avatar
BEZ06
Originally Posted by CADbrian
I....Response from GM parts vendor:
This part number [13348393] was just confirmed by a local Chevy/GM dealer as being the correct part number for 2018 models...
I'm not quite 100% certain that part# wont work - only about 99.9999% that IS NOT a sensor for any year C7. It looks like something that might have been used 15 or more years ago in a C5, and if you do a search for that part# on eBay you'll see it says: "For Opel Saab Chevrolet Lotus", and the only Chevy it says it works with is the Volt.
Like gtam85 says he used in his 2018, get a part# 13581560 like he used, or that part# was superseded by a different part# 13598775
Either of those sensors will work, but the 13598775 is the newer part#.
Just MHO, YMMV!!
Bob
To TPMS for 2018 Corvettes
