Remove windshield header trim?
Old Dec 29, 2017 | 01:22 AM
Kent1999's Avatar
Kent1999
Default Remove windshield header trim?
Hi all,
Does anyone have a link or instructions for removal of the windshield header trim (the part that surrounds the interior rearview mirror) and the mirror itself (if needed)?
Did a forum search but for some reason the info I was looking for wasn't coming up.
I'm running a dedicated wire to power a dashcam and detector, and I'm going to hide some connectors and wiring under that center trim.
I thought it just pulled straight down, but instead of just popping free, it's just flexing/stressing to a disturbing degree, so I want to make sure I'm not missing something before I go all superhero on that piece of plastic.
Thanks!
Old Dec 29, 2017 | 01:33 AM
CVSUINES's Avatar
CVSUINES
why do you want to remove it , just use panel tool to push the wires in
Old Dec 29, 2017 | 10:39 AM
Kent1999's Avatar
Kent1999
That would be easier but I need to mount some other components behind it, so I need to remove the trim.
Old Dec 29, 2017 | 12:04 PM
Bmwmike's Avatar
Bmwmike
you will find 1 screw under each of visor lock tabs ans then more under the visor swing arm. the mirror then needs to be twisted to come down and unplugged. after that it is just clips you can yank down on it.
Old Dec 20, 2019 | 10:58 AM
RiCorvette's Avatar
RiCorvette
Vid for removing the Windshield - Header Trim removal at 14:30 ~
Old Nov 26, 2025 | 09:27 PM
donuts_rock's Avatar
donuts_rock
This was a hard video to find! Thanks for posting!
To Remove windshield header trim?
