Header install - my tips to help
Old Feb 4, 2026 | 07:26 AM
Ahunei10's Avatar
Ahunei10
1st Gear
Default hard to reach bolt on exhaust connection to manifold
I found it easiest to use a semi-deep socket and a 3/8 flex head with a medium length handle. Passenger side same thing you can break them loose. Mine was a little tight so I put a pipe on the end of the handle.
