Side window venting question
Old Feb 10, 2018 | 11:22 AM
GregHall's Avatar
GregHall
1st Gear
Default Side window venting question
2017 Corvette GS. What is the technology behind the side window moving down slightly when the door is opened, then moving back up when the door is closed? I know its purpose, but how does it work? Shape Memory Alloy?
Old Feb 10, 2018 | 11:36 AM
DWillys's Avatar
DWillys
My guess is that it is nothing special. The C7 knows you are going to open the door, it tells the motor to run for a short time, enough to clear, and then stops.
Old Feb 10, 2018 | 12:14 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
The advantage of stepper motors.
Old Feb 10, 2018 | 12:17 PM
Bill Dearborn's Avatar
Bill Dearborn
The door switches send a signal (more likely a ground connection) to the door control module which initiates the door opening process. My 2008 Z06 suddenly developed a nervous window when it started going up and down between the door open and door closed position. The dealer replaced the door control module and the problem went away. I suspect the C7 architecture is basically the same although the actual module involved may be a newer technology.
Bill
To Side window venting question
