3rd Brake Light repair or replace?
Old Feb 15, 2018 | 09:21 PM
TorchZ51's Avatar
TorchZ51
Default 3rd Brake Light repair or replace?
I have a couple elements burned out on my 3rd brake light under the rear spoiler. Looks like the entire rear facia needs to be removed to get access. Can the 3rd brake lights be repaired, or is it just a remove and replace the entire light?
Old Feb 15, 2018 | 10:42 PM
Bill Dearborn's Avatar
Bill Dearborn
If the car is under warranty I would take it to the dealer to see if it is covered. They are LEDs and probably are replaced as a unit. The part is ~$165 at a discount. A fairly expensive price for something that is basically a series of diodes.
Bill
Old Feb 16, 2018 | 01:26 AM
geewez's Avatar
geewez
I doubt very much if you can replace just the burnt out lamps. More than likely the LEDs are all soldered on a strip or a board.
Old Feb 18, 2018 | 04:25 PM
ChuckerC7's Avatar
ChuckerC7
To replace the LED unit, you'll need to pull the rear facia cover off. If you google youtube Chevydude he has a video on how that is done in less than 20 minutes
Old Feb 18, 2018 | 09:30 PM
TorchZ51's Avatar
TorchZ51
Thanks for the tip on the video of the rear facia removal. I posted it here....
Old Feb 19, 2018 | 07:59 AM
rrsperry's Avatar
rrsperry
Great time to add a brake light flasher to the CMHSL.. (Center mounted high stop lamp)
To 3rd Brake Light repair or replace?
