MAGNETIC RIDE CONTROL/wheels
Old Feb 18, 2018 | 03:17 PM
ronzusa's Avatar
ronzusa
3rd Gear
Default MAGNETIC RIDE CONTROL/wheels
Can the 18" front and 19" rear wheels be installed on a C7 (2016) that has MAGNETIC SELECTIVE RIDE CONTROL?
Old Feb 18, 2018 | 08:25 PM
rrsperry's Avatar
rrsperry
MRC doesn’t care what wheels you have as long as they clear the brakes, and the tire diameter is within 4% of stock.
Old Feb 18, 2018 | 08:53 PM
BrunoTheMellow's Avatar
BrunoTheMellow
To add to that, the base 18 and 19 inch wheels will not clear the stock front brake pads. I highly doubt OP has non-stock pads.
Old Feb 18, 2018 | 11:56 PM
AmmoVet's Avatar
AmmoVet
I’m told the split spoke 18/19’s will fit. I understand some folks use them on the Z51 to get a better choice of tires for autocross.
Old Feb 19, 2018 | 09:48 AM
BrunoTheMellow
Ah you're right, what was I thinking, I just posted a thread of this exact same topic. Here are the details:
18" wheel will fit front Z51 calipers and stock pads if you move the wheel weights to the inside of the wheel.
18" wheel will fit front z51 calipers and non stock pads without having to move the weights. That's what I have.
https://www.corvetteforum.com/forums...nt-brakes.html
https://imgur.com/gallery/Emqjk
https://www.corvetteforum.com/forums...1-fitment.html
Old Feb 22, 2018 | 03:54 PM
Bill Dearborn's Avatar
Bill Dearborn
Not sure you can make a blanket statement about non stock pads. The pads can change depending on the manufacturer. There are slight differences in backing plates they can choose and then you have the problem of where they place the braking compound on the backing plate. I have had 3 different pads made to fit the same caliper and none of them were identical. Close to each other but still different and all will work in the caliper.
Bill
Old Feb 22, 2018 | 05:37 PM
BrunoTheMellow
Bill
do any aftermarket pads have the noise dampeners? Because that is what would rub. 1/4" gap to wheel weights from caliper body otherwise.
Old Feb 22, 2018 | 11:33 PM
ronzusa's Avatar
ronzusa
3rd Gear
Default Stingray with optional Magnetic ride
So I'm assuming that my 2016 2T Stingray with the optional Magnetic suspension (comes with 19"/20" wheels), but standard brakes, should not be a problem for 18"/19". There appears to be an inch of clearance between the calipers and the (19"/20") weights.
Old Feb 23, 2018 | 10:58 AM
AKKutz's Avatar
AKKutz
I run 18/19 oem wheels with Pirelli Sottozero winter setup on my Z51 with Mag shocks and stock pads. I had to relocate the inner wheel weights (on the 18's)to closer to the outside of the rim. The wheels clear the oem brake pads, the wheel weights will not.
I run the same type wheel with NT-01 for the track with PFC pads and DBA rotors. Not issue with wheel weights with these pads.
Old Mar 9, 2018 | 08:50 AM
dfettero's Avatar
dfettero
Default GM Brake Kit
GM Z51 Brake Kit for base model
GM Part 23386143
To MAGNETIC RIDE CONTROL/wheels
