Shudder issue on C7 Z06
Old Mar 8, 2018 | 02:32 AM
Bruce Millner's Avatar
Bruce Millner
Default Shudder issue on C7 Z06
Hi. My car shudders for about the first 5-10 miles and then it goes away.
I have ascertained that a couple of the wheels are slightly buckled, but this doesn't explain the issue given it goes after driving a few miles.
Possible issues:
- flat spot on the tires
- cold tires
Any help appreciated. It didn't do this when I got it 12 months ago.
TIA Bruce
Old Mar 8, 2018 | 03:44 AM
C7GrandSportC7's Avatar
C7GrandSportC7
Possible issues:
- cold tires
TIA Bruce
It's the tires. Are they the OEM tires?
Old Mar 8, 2018 | 04:44 AM
Bruce Millner
The fronts are practically new Michelin OEM done maybe 2,000mi and the rears same and 3,000mi.
Can't send them back either as the car is in New Zealand and the tires are from Tirerack!! You can't get them in NZ
Old Mar 8, 2018 | 07:18 PM
spearfish25's Avatar
spearfish25
My car is a lump-fest for the first 4 or 5 miles if it's been sitting. This has been true of Supersports, Cups and Continentals. While the Contis have the best ride, they also seem to have the worst temporary flat spots.
Old Mar 8, 2018 | 07:24 PM
383vett's Avatar
383vett
By shudder, do you mean a vibration issue while going straight at speed or tires grabbing during slow turns when cold?
Old Mar 8, 2018 | 08:00 PM
Bruce Millner
OK. So this would seem to mirror my problem as the car has been sitting. Thanks
Old Mar 8, 2018 | 11:03 PM
Bruce Millner
Thanks. Yes this seems to be the issue. It's been sitting
Old Mar 10, 2018 | 09:20 PM
Avanti's Avatar
Avanti
Interesting; temperatures? Setting how long? The PSSs on my '18 do NOT do this (I've put 2500 miles on it) and I let it set a week or two at a time, and drive it in temps down to around 45-degrees F.
Old Mar 11, 2018 | 10:50 AM
spearfish25
I find it to be more of an issue if it's warm, particularly when you go to park the car initially. The warm tires are more pliable and then will take to the flat contact point more when parked.
It goes away once you get them warmed up again.
Old Mar 11, 2018 | 12:23 PM
mdolandese's Avatar
mdolandese
How long was it sitting just curious?
To Shudder issue on C7 Z06
