Hood Vent Remove & Replace
Old Mar 10, 2018 | 03:32 PM
bankers1's Avatar
bankers1
Default Hood Vent Remove & Replace
Am I REALLY supposed to "pound out" the old vent? I've seen the Utube???
I'll brake a few of the nylon tabs, I'll crack/brake some fiberglass in the hood.
,17 GS CE #663 NO center line in Vent (non Z06)
I've go the over off, the clip "Tool", it seams impossible/timely to try to remove
each (10 clips) while hood is installed... Help.... Albany, NY
Old Mar 11, 2018 | 01:18 AM
Kohler717's Avatar
Kohler717
? I’ve removed my hood vent to wrap my hood. Definitely thought I was gonna break it. But it turns out it’s super strong and you have nothing to worry about
Old Mar 11, 2018 | 01:36 AM
KGrant's Avatar
KGrant
Nice steady pressure hit around the edges with palm of hand or rubber mallet will do the trick. Worked for me!
Old Mar 12, 2018 | 08:23 AM
JGarland's Avatar
JGarland
Slip a shop towel through the vents and grab both ends... Then yank real hard.
Old Mar 12, 2018 | 09:50 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Do not yank, pull, jerk, tug, hit, strike, dynamite, bludgeon, slap, twist, thump, punch, knock, bang, cuff, smack, tap, spank, stroke, welt, karate chop, chisel, hammer, spindle, fold or mutilate on anything. It is easy as hell to get the vent out of the hood. Give me a minute to find the thread.
Here:
https://www.corvetteforum.com/forums...post1591069511
Pry the first spot a little to get some movement, then go to the next tab and pry a little, continue around the vent and by the time you get back to the first spot, the vent will probably fall off the hood into your hands. Work smarter; not harder.
Elmer
Last edited by eboggs_jkvl; Mar 12, 2018 at 11:12 AM. Reason: Added link and a few more "Do Nots".
Old Mar 12, 2018 | 11:14 AM
JGarland's Avatar
JGarland
Here:
Elmer
Yanking with a shop towel worked for me. Nothing broke and it popped right out.
I was shocked.
Your mileage may vary.
Jus sayin'
To Hood Vent Remove & Replace
