C7 DiabloSport T2 impression....
Old Mar 15, 2018 | 06:26 PM
MaseR09's Avatar
MaseR09
2nd Gear
Default C7 DiabloSport T2 impression....
Firstly, first time poster here and owner of a 2014 Z-51:
Secondly, this isn't a T2 bashing thread. I was truly ecstatic when the Trinity T2 was released. Although I was interested in the ability to add a Diablo tune, I was more interested in the real time monitoring feature that the T2 offered. The amount of "pids" which can be observed is truly amazing! However, my excitement quickly turned to utter disappointment. The 93 octane tune loaded without a hitch. However, EVERY time I tried to access the monitoring/gauges tab it locks up and the screen goes black. This feature is completely unusable. 3 weeks, countless "updates/sync's", and 3 different Tech guru's later: still no resolution. My grievance was apparently forwarded to an engineer last week but still have not heard a thing. This really is disappointing!!! Next step I reckon is sending the thing back. Working at 100% of its capability, there no doubt this product is outstanding however UNTIL DiabloSport gets these software glitches worked out, I advise others considering to steer clear...
Sincerely,
Mason R
Old Mar 16, 2018 | 03:22 PM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
Odd.. I have the T2 and use it on my 2016 Suburban, and all gauges, logging, monitoring work fine with no issues...
have you updated it to all the latest updates/fixes using the Ignition Updater software???
the first thing you will need to do is download and install the Ignition Updater program - this program is used to update your Trinity T2 to the latest updates/fixes - https://www.diablosport.com/downloads/
Once that is installed, then connect the Trinity T2 to your computer and let it start up and get to the main screen.
Then launch/run the Ignition Updater program. It will search for and find your Trinity T2 and will start downloading any new updates. The Trinity T2 will install the updates on itself, you may need to reboot it so follow its on-screen instructions -- and when it's done and everything is up to date, the Ignition Updater program will show that your Trinity T2 is now up to date.
You can find updating info/instructions in the full user manual that is included in the Trinity T2 box you received... There could be a few updates, so it could take a little while...
Here's the full user manual: http://www.diablosport.com/content/u...2500_REV00.pdf
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Mar 16, 2018 | 03:36 PM
Mike@DiabloSport's Avatar
Mike@DiabloSport
Supporting Vendor
Mason, I am sorry to hear you are having these issues.
I want to assure you that our team is working to resolve this issue asap.
It sounds like you have contacted us about this, but to confirm, would you mind emailing me the serial number of your device so I can make sure your issue is documented on our end?
mlitsch @ powerteq .com
Old Mar 16, 2018 | 05:31 PM
MaseR09's Avatar
MaseR09
2nd Gear
@Mike ----> Just shot you an email. Lemme know if there is anything else you need
@Monte---> Yup have tried everything you suggested including multiple resets over the phone from DSport. At my wits end!!
To C7 DiabloSport T2 impression....
