You said it yourself, back in the days. Tires nowadays are better. Summer tires can be run on the track without shaving. The stock MPSS ZP can run hard track days just fine straight from the show room, yeah they will wear but not chunk off.
My stock tires with a proper track alignment in 3 sessions, when the car was bone stock. Tire presure was 36 to 38 hot. I tried to keep it around 36.
That's crazy. I retract my statement but 38 is too high for those tires. Your center treads chunked off, likely the center was ballooning out. You sure it didn't go closer to 40?
It may have on track, but not when I checked in the pits. I was pushing through understeer exiting the sweeper at Buttonwillow. I did not treat them nice. They don’t seem to like understeer at triple digits lol.
hah. This is my my right front Hankook rs3 after a good 8 track days on them, -2.0 camber, on a track with three 85 mph turns on that side (they last a while but grip is not good). I elected to retire them a little early to put better street tires on and a track-only set of r888rs of similar size (which on first try ran 4 seconds a lap faster on a 1:25 minute lap track, stock mpss was right in the middle of the two time-wise)
The "optimum" pressure is going to vary some depending on which tires, how they are prepared (tread depth), car setup (alignment and weight balance) and which track you're at.
Aiming for 34 psi to 36 psi hot is probably going to get you in the ball park. At Palm Beach International, I doubt you could ever get down to 32 psi hot unless you are driving slow.
One clue that you're getting too low is if you drop a pound out of the things before starting the session and your hot pressures go up. When that happens, you're definitely too low.
If you have access to a tire pyrometer (with the probe that sticks in the tread), you can get a better idea of what's going on with temperatures. An infra-red, no contact "point and shoot" thermometer is pretty much useless, though. You need carcass temperatures, not surface temps. The only way the no contact infrared thermometer works is if you have 3 of the sensors on board for each tire, and a data recording system. Then, looking at the logs in the middle to end of the hardest turns can give you some useful data points.
Thanks for all the great feedback. I had tracked with the MPSS run-flats but they also chunked off. I assumed that was because of the stiff sidewalls. My runs on MPSS were good but I wore them out really fast. That got expensive. That's why I'm trying out cheaper tires. I remember when I first bought my C7, the GM website published recommended track alignment specs but I can't find them anymore. Does anyone have them? With the stock wheels, what are the best bang-for-the-buck tires?
I ran full tread MPSS earlier this week on my Z06 for 4 sessions without issue. They did lose grip after 3-4 hot laps and if I wanted to get another good time I had to back off for a lap and go again. I managed a 2:00.21 at VIR on them. This is with DSC recommended track alignment.
