Power door switch replace?
Old May 24, 2018 | 09:13 PM
weatherby460's Avatar
weatherby460
Default Power door switch replace?
I need to replace the drivers side power door switch because of cosmetic damage. I got a new switch on order. Any idea, how hard it is to replace? Thanks
Old Jun 3, 2018 | 08:53 PM
weatherby460
Any help appreciated.
Old Jun 15, 2018 | 08:23 PM
weatherby460
Any idea?
Old Jun 15, 2018 | 09:23 PM
RonC7's Avatar
RonC7
OP - your question is not clear.
See the attached on how to replace the driver's door "open" button. The procedure should also give you access to the lock / unlock button.
The external finger pad has 2 torx machine screws to remove - you don't need to pull the inner door panel.
Which item are you trying to replace?
https://www.corvetteforum.com/forums...rim-panel.html
Ron
To Power door switch replace?
