Looking for cam advice
I do not track the car, but would like to in the near future. My wife drives the car occasionally, so it does need to have decent street behavior. I do not want her to have to worry about bucking or other side effects of the more aggressive cams. I would also like to maintain as much of the low end torque as possible. I am ok with AFM delete.
I have never owned or driven a car with an aggressive cam, nor have I heard one in a C7 live. I would appreciate advice / input from others who have gone down this path with their C7. If you have a set-up on your car that you believe would work for me, it would be great if you could post a sound clip and dyno results, if available.
I also looked at the packages from Lingenfelter and Vengeance Racing. Would love feedback from anyone running those packages assuming you think it fits my goals. Thanks in advance for your input.
Intentionally destabilizing your idle can cause driveability problems, of course, so there's a tradeoff involved.
Your goals are definitely realistic and we are happy to help where we can! Our full Cam Kit Plus package is on sale right now and will come with absolutely everything to perform the install. That being said, you really need longtube headers and a good cold air system (we offer Kooks/ARH, and Halltech/AFE respectively if you need these items) for optimal performance and the sound that you're looking for, as well as a good tune on the car as that is the most important piece for drivability.
As for the camshaft itself, we offer our "Stage 2 LT1" cam for your exact goals. This camshaft gives a great increase in performance across the power band, aggressive lope at idle, but still maintains both low-end torque and excellent drivability.
The other thing to consider when doing the install is a set of CNC ported cylinder heads. These will give another 15-20rwhp on average, and there is no additional labor involved since the heads have to be removed for your AFM delete anyway. It also saves time on the install overall since they come loaded with dual valve springs and eliminates the need for an install tool or the time to setup the springs. We just simply require your OEM heads back as a core to make the swap easy.
Here's another Stage 2 camshaft equipped M7 C7 for reference:
Here's some links for the Cam Kit Plus as well as our heads/cam package also:
https://vengeanceracing.net/2014-c7-...lus-gen-v.html
https://vengeanceracing.net/2014-c7-...lications.html
Feel free to call or e-mail me (david@vengeanceracing.net) at any time if you have any other questions on this or if we can help with setting you up on a package!
