Oil change??
Old Jun 12, 2018 | 12:49 PM
michaelmik's Avatar
michaelmik
Default Oil change??
I purchased a new C-7 Grand Sport, last spring, but only put 127 miles on it, before winter storage, [ cover, battery tender, etc. ] Question is , after sitting all winter, is it OK, to drive, until 500 miles , for dealer first oil change?
Old Jun 12, 2018 | 12:54 PM
juanvaldez's Avatar
juanvaldez
Yes.
Old Jun 12, 2018 | 01:51 PM
hammong's Avatar
hammong
Poor neglected car is begging to be driven. Definitely OK to drive, nothing "happened" to the oil while it sat around in the garage.
Old Jun 12, 2018 | 06:23 PM
Gsportz's Avatar
Gsportz
3rd Gear
Absolutely. Oil would take a much longer time to break down especially seeing only 127 miles.
Old Jun 12, 2018 | 07:17 PM
laserdude2215's Avatar
laserdude2215
Does the warranty matter to you? If yes, then you should change the oil as indicated by the oil life monitor.
Old Jun 13, 2018 | 10:40 PM
TEXHAWK0's Avatar
TEXHAWK0
Makes me wonder why anyone would buy a new car knowing they could not drive it until after winter.. Remember, that the reason for the 500 mile oil change is because the off gas from the curing of the silicone used during assembly can deplete the anti-foam agents in the oil.. If you are not driving the car hard enough to worry about foaming, then you can wait until the 500 mile mark.
Old Jun 14, 2018 | 07:35 AM
Patman's Avatar
Patman
The OP bought his car in the spring though.
To Oil change??
