NPP; AFM Actuators; Wiring help
Old Jun 17, 2018 | 08:17 PM
g8germany's Avatar
g8germany
6th Gear
Default NPP; AFM Actuators; Wiring help
Hello,
i have order two rear Muffler with afm Actuators.
Here I have read that this wiring would be right.
Pin
1:Ground
2:Ground
3:Feedback open
4:12V
Is that so correct?
If I wiring this so, the actuoator will just make a step about 2mm.
If I Pull pin 2 to ground and not and again. the motor will drive to open.
How can I Force the motor to drive to close?
Thanks for help
Old Jun 17, 2018 | 09:25 PM
falcon5619's Avatar
falcon5619
What exactly are your trying to accomplish? Are you trying to add NPP exhaust to a model without NPP?
Old Jun 17, 2018 | 11:29 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Originally Posted by g8germany
Hello,
Pin
1:Ground
2:Ground
3:Feedback open
4:12V
Is that so correct?
Thanks for help
I don't believe you can accomplish what you are trying to do. The valves cannot be controlled by simply applying power and ground to the correct pins. The actuators require a VERY specific PWM (Pulse Width Modulation) signal to them to operate. If the signal it receives is outside of the expected parameters, it will freak out the actuator and lock itself open and will never reset itself, basically toasting the actuator entirely. If you want to add NPP to a non NPP C7, buy the controller kit from Akropovic. Its not cheap, but it does work.
Sounds like it..
Old Jun 18, 2018 | 02:52 AM
g8germany's Avatar
g8germany
6th Gear
Hy,
I try to run the AFM Valve.
I will fit the C7 Muffler with NPP under my Pontiac G8 with NPP.
Here is the Wiring Diagram what i have found
Here I have read that I just connect 4 Wirres LINK
What is now right.. Simple Ground or PWM signal to close the AFM.
Can somebody tell me what the right PWM frequenz..
Old Jun 18, 2018 | 07:07 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Hy,
The AFM actuators are the same type of actuator as the NPP actuators. The below thread will have more info on a retrofit and I can assure there there are no other threads on the forum with more info than it lol. Theta, who previously did all the work to figure this out, has not been on the forum for some time so you cannot contact him.
https://www.corvetteforum.com/forums...-retrofit.html
Ant
Old Jun 21, 2018 | 07:53 PM
g8germany's Avatar
g8germany
6th Gear
Thanks for the fast help.
I have rebuild a Control with Arduino Mega and no C7 NPP Retrofit PCB. Just Some parts for around 10$ and Software
I have kill one Actuator at Rebuilding
If Somebody is selling one, I will buy it.
Old Jun 21, 2018 | 08:28 PM
Higgs Boson's Avatar
Higgs Boson
just FYI, we have control of the C7 exhaust valves in HPTuners now. :-)
Old Jun 21, 2018 | 08:36 PM
g8germany's Avatar
g8germany
6th Gear
thanks but i build the c7 muffler under my pontiac g8,
I think this ECU doesn't support it
Old Jun 21, 2018 | 11:50 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
wait what? Did the version 4 upgrade add that or are you referring to the AFM valves? What can we control for NPP in HPT now?
Old Jun 23, 2018 | 09:01 PM
Higgs Boson
everything. download the latest beta, you need to read out the chassis control module and license it.
Old Jun 23, 2018 | 09:11 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
awesome. I already licensed the CCM when I did the AFM valve delete.
Old Nov 3, 2018 | 12:16 PM
Steve_aleve's Avatar
Steve_aleve
1st Gear
YOUTUBE
i have an actuator from the eco mode that I am not using that I think is the same. I am also trying to do what you did. Can you elaborate on the parts and software? Thanks!
Old Jul 8, 2020 | 05:02 PM
Corvettes_Rule123's Avatar
Corvettes_Rule123
1st Gear
@g8germany - That's awesome! Could you explain what parts you used with the Arduino to get this working? What signal did you end up feeding the device? Thanks in advance
To NPP; AFM Actuators; Wiring help
