Oil Change Q
Old Jun 23, 2018 | 10:56 PM
cortex's Avatar
cortex
Default Oil Change Q
Synthetic oil is shelf stable for at least 5 years according to ExxonMobil. So, if I use the dexos 1 and hardly drive any miles why do I need to change it every year? I liked my C5 "oil life remaining" algorithm. It treated me well for 240k miles and the engine still pulled strong. It did not take into account time.
Old Jun 24, 2018 | 06:46 AM
Patman's Avatar
Patman
It's true, oil in a sealed bottle is good for at least 5 years but once you put that oil into an engine, it's a different story because you have blowby gases and acids contaminating that oil and shortening it's effective life span.
Old Jun 24, 2018 | 06:57 AM
salcolkat's Avatar
salcolkat
I believe the oil life indicator on the C7 will say the oil change is due every 12 months regardless of milage.
Old Jun 24, 2018 | 08:47 AM
Kracka's Avatar
Kracka
Everything is shelf-stable for a longer period of time when in a sealed container.
Old Jun 24, 2018 | 01:03 PM
Patman's Avatar
Patman
Another reason why I think the 1 year oil change is very important on the C7 is the fact that it uses direct injection, and that makes it more susceptible to fuel dilution in your oil. Therefore you don't want that oil in your engine for 2 or 3 years, even if you've only driven 1000 miles during that time period. So even if a 2 or 3 year oil change interval was successful on the C5s and C6s, the chances of it being successful on the C7 is much lower.
Old Jun 24, 2018 | 01:52 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
THEN YOU DIDN’T READ OR FOLLOW THE OWNER’S MANUAL!
This is what it said in my ‘93 Vette Owner’s Manual
1) Change oil at 7500 miles OR ONE YEAR WHICHEVER OCCURS FIRST!
2) If most drivers are under 4 miles change oil at 3000 miles OR 3 MONTHS WHICHEVER OCCURS FIRST!
Said change Max 1 year for my ‘88 Vette, my S10 truck etc! The worse thing for oil and engine is a cold start. Combustion products pass the large clearances. Water is a main combustion product and forms acids with the other combustion products that pass the rings as does the excess fuel required to start and keep a cold engine running! Like sulfuric acid and others. Rather than GM’s old estimate of miles driven the OLM measures oil temp after a cold start. If it does not get hot enough long enough it will shorten the time to change, Perhaps won’t say change but if all drives are short it might.
I change the oil in my Street Rod annually that mostly goes to local shows. I also will not pull it out to get to a ladder etc without driving ~20 miles to evaporate some of that water (and have fun.). That acid that forms is cording metal engine parts when it’s not running!
If foolish enough to start a low mileage Vette and pull it right back in the garage you should probably change every 3 months!
OP’s car his choice.
Old Jun 25, 2018 | 09:15 PM
cortex's Avatar
cortex
No worries, thanks for your input. Sounds like prior 'oil life remaining' algorithms should have included time!
Old Jun 29, 2018 | 10:37 AM
wolfie5254's Avatar
wolfie5254
Does anybody know what’s going on with the Mobil 1 ESP Formula 0W-40 engine oil for the C7 LT1 Stingray?
Old Jun 29, 2018 | 10:52 AM
Patman's Avatar
Patman
I got an email from Mobil regarding the availability of this oil in retail stores:
Good Afternoon Patrick!
Our new 0W-40 for the 2019 Corvette, Mobil 1 ESP Formula 0W-40, is now available to retailers. Many of them may not be aware of it, however, until they see signs of customer demand. Retailers should now be able to order the product under the following part number:123875 - (Six 1 quart jugs)
Thank you for choosing Mobil,
Eryn
Mobil Help Desk Team
Old Jun 29, 2018 | 12:21 PM
Bill Dearborn's Avatar
Bill Dearborn
I suspect that GM changed the algorithm based on warranty experience. They either saw increased repairs attributable to oil life issues or the composition of the oil has changed over the last 20 years due to changes in regulations.
Bill
To Oil Change Q
