HMI module
Old Jun 28, 2018 | 01:37 AM
mmorse's Avatar
mmorse
Default HMI module
im having issues with the screen on my 2014. want to check the connections on the hmi module. it’s behind the driver side kick panel. any vids or instructions on removing that kick panel? probably an easy thing to do but a guide to follow would keep me from possibly break or screw up something
Old Jun 28, 2018 | 09:02 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Actually, it is above the kick panel and fully visible to work on. You can disconnect the 4 or 5 leads that enter on the bottom and slide the unit down and out if you'd like. Removing the kick panel is one piece of trim at the top that lays on the kick panel and then prying up on the piece of KP on the floor. BUT, you don't really have to remove the kick panel to mess with the HMI.
Elmer
Old Jun 28, 2018 | 11:51 AM
mmorse's Avatar
mmorse
Elmer
thx much Elmer.
Old Jun 28, 2018 | 03:11 PM
mmorse's Avatar
mmorse
Originally Posted by mmorse
thx much Elmer.
i found the module and could see the harness and were the plugs are. problem is i’m too big to actually get at it and do anything about it. it’s just too tight for me. don’t know how anybody can get to it. oh well. plan B i guess.
Old Jun 28, 2018 | 04:12 PM
eboggs_jkvl
Moderator emeritus
In this matter, size does matter! I'm 5'6" at 157 pounds and I can get in there and molest the hell out of the HMI! Bribe a smaller friend to get in there and check the connections. The connections are small and lock in place. A simple nudge up on each of the connectors will be a chack on a valid connection.
Elmer
Old Jun 28, 2018 | 04:55 PM
Avanti's Avatar
Avanti
A small, dexterous friend can be invaluable working on cars! One of the best "tools" to cultivate!
Old Jun 28, 2018 | 05:33 PM
mmorse's Avatar
mmorse
unfortunately i don’t know anyone who is both small and dexterous. at least nobody i would trust tinkering with my car. LOL!
Old Jun 29, 2018 | 06:44 PM
eboggs_jkvl
Moderator emeritus
Move to Florida, I'll help you and I work for beer!
Elmer
Old Jun 29, 2018 | 08:52 PM
mmorse's Avatar
mmorse
Elmer
i would love to take you up on that but i’m 3000 miles from you. a tad impractical! 😅
Old Jun 30, 2018 | 05:52 AM
Flame Red's Avatar
Flame Red
If the issue with your screen is the "flicker" where the screen goes blank and sometimes comes back a while later, the problem is probably not with your HMI. The internal ribbon cable that connects the screen to the frame is the culprit.
There is a company that rebuilds them but I cannot find the post with their name. I believe they send you a rebuilt one with a deposit for your core. Much cheaper than going to the Stealership and having them install a rebuilt replacement or a new one. The other option of course is new from GM but that is expensive. Replacing the screen is a bit of a pain as you have to remove the dash front and center console to get at it. Good opportunity to install a CF dash while you are in there. There are great how-to thread here on both topics. It is a few hour work. Not hard, just be patient.
Old Jun 30, 2018 | 10:47 AM
ROD BROWN's Avatar
ROD BROWN
Default I'll give you a hand
I live in Holly wood and I am 5'8" and I replaced the HMI in my 2016 Vette. I am retired and I can drive up to your area and get under the dash and check it out for you.
Old Jun 30, 2018 | 08:19 PM
mmorse's Avatar
mmorse
thanks Rod for the kind offer but i found out my extended warranty will cover a screen replacement. saw the original owner last night and he told me the screen had been replaced once before. looks like my best bet is the dealer after all.
Old Jul 1, 2018 | 11:37 AM
ROD BROWN's Avatar
ROD BROWN
Good luck
Old Jul 1, 2018 | 01:17 PM
mmorse's Avatar
mmorse
except it only flickers when the car is in reverse which could indicate a rear camera or cable problem. decided to let a dealer figure it out. just need to find one that actually knows how to work on corvettes. my local dealer sure doesn’t have a clue.
Old Mar 24, 2022 | 10:55 PM
gill_2lz's Avatar
gill_2lz
New Member
please assist me with my corvette lol. I live in chino hills area
To HMI module
