Base Stingray Brake Upgrade
Old Jul 5, 2018 | 06:34 AM
malexand123's Avatar
malexand123
Default Base Stingray Brake Upgrade
I have a 2017 Base Stingray LT3 (non Z51) and am going to turn it into a track car... not dedicated... a driver/track car...
While simultaneously working on brakes, I will have a few other items going, but this thread is for brakes. Brake COOLING will be a switch to the Z06 grill and cooling ducts up front.
AP Racing..... Brembo GT / GTR .... Racing Brake.... Others I should be considering? Ones I should NOT be considering? The choices are dizzying!
Old Jul 5, 2018 | 10:07 AM
dfettero's Avatar
dfettero
Look at KNS. Just upgraded my 2016 Base model to Z51 front (yes they fit ) and rear slotted DBA 4000 rotors and the DBA XP650 Track pads. Upgraded front calipers to Z51 - rears the same.
Love the DBA SP500 street pads (Very, very little dust). Use RBF 600 or similar brake fluid with an ABS flush by the dealer..
Old Jul 5, 2018 | 10:27 AM
Jeff V.'s Avatar
Jeff V.
The big Z06/Grand Sport brake packages will fit as well. Though you might need spacers or different wheels to clear them.
Old Jul 5, 2018 | 10:35 AM
malexand123
For up front I'm looking for big brakes.... 14.5 - 15.5-ish sized.... 2-piece.... 6 pot.....
Rear stock size is fine... would ~like~ 2-piece, but not mandatory.....
The Z51 front brakes will be undersized for track use I have a feeling.
Old Jul 5, 2018 | 11:23 AM
The HACK's Avatar
The HACK
You should really find out what the true weak points are on the brake system before you throw money at it, IMO. Sometimes a simple pad and cooling solution may be as effective as a $4,000 brake kit.
Not saying there's no merit to buying a $4,000 brake kit from any of the reputable vendors like AP Racing, Brembo, StopTECH, RacingBrake...etc. They all increase heat capacity without sacrificing unsprung weight to some extent. But you really should find out the WHYs before asking HOW.
I fully intend on taking my '17 GS on track a few times before I throw any money at anything (except I already threw money at alignment, but that's what GM recommends), even though based on my experience with my previous cars I already have a good idea on what it needs.
Old Jul 5, 2018 | 12:03 PM
malexand123
Sorry i wasn't clear before.... I do intend to do some cooling in advance of the actual upgrades... and some track days after the cooling upgrades and before any hardware changes... just to see where we stand.... Based upon other's experience however, I don't anticipate avoiding hardware changes... hence the question and at least trying to understand what options there are and how people feel about them. Hopefully that makes sense.
Old Jul 5, 2018 | 01:23 PM
ap6954's Avatar
ap6954
AP Racing J hook rotors and agressive pads on stock calipers was enough brakes for my z51 and my driving. I run carbotech pads but I think pads are a driver preference so choose ones you like the feel of. I put the z06 grill and add on front cooling ducts also. I agree with the former post. Unless your a very experienced driver and know you will over drive the stock stuff, start with the obvious like DOT4 fluid, and pads and drive it to find the weak points for your driving style and level.
Old Jul 7, 2018 | 01:07 AM
Michael Jarvis's Avatar
Michael Jarvis
I have '16 base stingray, and I recently upgraded to the Wilwood Big Brake kit after getting brake fade at Sonoma Raceway. Made a couple youtube videos about it, here's the unboxing
I eventually did a day at Laguna Seca, and had zero brake fade. Very happy with the results
Old Jul 7, 2018 | 10:46 AM
Taz Golf's Avatar
Taz Golf
Yes you are definitely correct in needing different wheels and spacers as I just did this on my sister's Stingray!
Old Jul 7, 2018 | 10:52 AM
jonparks's Avatar
jonparks
Originally Posted by Michael Jarvis
I have '16 base stingray, and I recently upgraded to the Wilwood Big Brake kit after getting brake fade at Sonoma Raceway. Made a couple youtube videos about it, here's the unboxing https://www.youtube.com/watch?v=WmhpXHpMQ_8
Michael,
Did you notice any difference with the added unsprung weight?
Old Jul 7, 2018 | 11:45 AM
malexand123
Can you elaborate on the specs of the wheels you went to? Or at least the effective specs with the spacer?
Old Jul 7, 2018 | 05:26 PM
badhabit_wb's Avatar
badhabit_wb
The AP setup is hard to beat. I was having issues with the z06 brakes not holding up on the track. I just put the AP's on and have only run one track day but they still look like new.
To Base Stingray Brake Upgrade
