Ported TB and manifold?
Old Jul 22, 2018 | 05:26 PM
Kraka46's Avatar
Kraka46
Default Ported TB and manifold?
Does anyone have a Z51 with a ported TB and intake manifold only? If so, do you have a custom tune? Also, what's the car drive like? I'm thinking about adding those two mods to my stock M7 Z51.
Thanks,
Mike
Old Jul 22, 2018 | 10:29 PM
Dcasole's Avatar
Dcasole
No tune is needed for those two mods
The ECM can more than make up any adjustment that is needed ...I can understand the ported throttle body as it will give u a bit better throttle response....but why the ported manifold ?
The stock manifold will more than outflow any need u might have from a stock LT1
Dave
Old Jul 24, 2018 | 10:54 PM
Internets_Ninja's Avatar
Internets_Ninja
Car will drive fine but you won't pick up much if you leave the stock intake and filter.
Old Jul 24, 2018 | 11:25 PM
Dcasole's Avatar
Dcasole
Why ? It's a Z51, not a Z06 , no gains were ever proven by changing out the stock intake and filter on a stock untuned LT1 ..adding a ported throttle body is not going to add any need for increased airflow requirements or produce any more hp over stock ....
I also question the need for an intake manifold on a stock motor .......
Dave
Old Jul 25, 2018 | 10:50 AM
Internets_Ninja
Dave
It's more of a whole package or none type of thing. There is dyno proven power by changing the Intake system, and adding ported TB/IM as a whole. But doing one without the other only nets very minimal gains.Also, without a tune you will leave power on the table. Personally, if you're not willing to tune the car, I wouldn't mod the car at all.
Old Jul 25, 2018 | 11:44 AM
Dcasole's Avatar
Dcasole
Thank you !
do you have a link as I would love to learn more ...
Back in the LS3 days folks would change out the stock manifold for a Fast102 and there was absolutely no gain unless you were doing heads, cam, headers etc as the LS3 manifold flowed really well , now there was a gain for the LS2 guys as that manifold did not flow that well
Dave
Old Jul 25, 2018 | 03:42 PM
Internets_Ninja
Thank you !
Dave
All over google. Just search for it.
https://www.corvetteforum.com/forums...ld-and-tb.html
https://www.camaro6.com/forums/showthread.php?t=470754
Old Jul 25, 2018 | 04:30 PM
Dcasole's Avatar
Dcasole
thanks
Dave
Old Jul 25, 2018 | 08:56 PM
ZNix's Avatar
ZNix
Ported IM and TB is worth it. A good CAI setup will also help. I haven't touched the tune in my stock 16 Camaro SS yet with a ported IM, TB, and Rotofab CAI. Still drives like stock imo.
Old Jul 25, 2018 | 10:42 PM
Gary barnes 1098's Avatar
Gary barnes 1098
Won’t notice a thing if these are the only mods with no tune!! Not too proud to say. Save your money . Been there done that. When I install my kooks with the upgraded tune,hopefully things change. Gary
Old Jul 25, 2018 | 11:07 PM
Dcasole's Avatar
Dcasole
I am with u Gary , the claims in those links were from the vendors ...ported throttlebody will add nothing as far as HP and I am having a hard time believing that you will get any gain out of a intake on a normally aspirated stock LT1 ..... the gains are in the tune and even then there is not much for a stock LT1 . Now add headers , CAI , tune and you are adding power you can feel as the 40 hp is across the whole power band ..., get those headers on ... I want ur x pipe lol lol
Dave
Old Jul 25, 2018 | 11:29 PM
spinkick's Avatar
spinkick
I have these with long tube headers, didnt really amount to much, the header and maybe the intake probably did some of the work, with the tune giving you the lions share of extra power. Its not a ton of power for what you spend, really.
Old Jul 27, 2018 | 12:45 AM
ZNix's Avatar
ZNix
Have to disagree here. I can definitely feel the power with CAI, Ported TB and IM without a tune. My HP tuners logs seem to show it as well. Once it is tuned, you will definitely see more of a gain. Throttle response increased as well. You have to think about what you are doing. Every little mod adds up.
Old Jul 27, 2018 | 05:32 AM
Gary barnes 1098
Whatever makes you feel better.
Old Jul 27, 2018 | 06:32 AM
Dcasole's Avatar
Dcasole
how does HP tuners show you that I are making power ..... do you track the car ? Or have you dyno the car ?
I will give you the improved throttle response but one does not feel a 10 hp gain .....
Dave
Old Jul 27, 2018 | 10:31 AM
spinkick's Avatar
spinkick
How do you use HP tuners to see the gain?
Old Jul 27, 2018 | 11:32 AM
Internets_Ninja
I can't speak for others experiences but when I did the CAI, ported TB/IM and tune on my car I def felt a power increase in the seat of the pants. Even how it revs to redline. It's just quicker. on HP tuners you can build PID's that output HP based on Torque math so you can see this change. Also, you can see the MAP/Airflow increase. IF you know how to use HP Tuners you can def see the change.
Then when I added ARH headers and a retune, I felt the increase in power as well. Now it just screams.
I would suggest everyone take internet opinions with a grain of salt. Some people are just ignorant, and some just spit out what they read someone else say who was ignorant. I'm not suggesting everyone on the internet is ignorant but rather to not take it as gospel. I myself have had C5, C6, and C7 corvettes and have modded everyone of them. I've also had a gen 6 Camaro SS. My experience tells me do your mods as a whole group and tune for them. Any other way is really a waste of time and money. The minimum bolt on mods I would do is CAI/Ported IM-TB/ and tune. Any less is worthless IMO.
To Ported TB and manifold?
Old Jul 27, 2018 | 12:00 PM
spinkick's Avatar
spinkick
Right, but I bet the increase you are seeing is from the tune more than the manifold and throttle body.
Did you do a before and after dyno?
Old Jul 27, 2018 | 02:07 PM
konqueror5's Avatar
konqueror5
I have a CAI ported TB and headers, tuned. Car felt faster and dyno'd 40 hp higher. I've seen folks get the same increase with just headers, granted different dyno, days, weather, etc. I'm on the side of go big or go home. I love the sound of the car but for power I could have saved the $3K and been halfway towards a SC already. In hindsight I would've skipped the CAI and ported TB but kept the headers for the sound alone.
Old Jul 27, 2018 | 05:25 PM
spinkick's Avatar
spinkick
I'm in complete agreement here with the same setup. This is exactly what I saw too.
