Elite’s E2 catch can
Old Jul 29, 2018 | 01:09 PM
KyleL's Avatar
KyleL
Cruising
Default Elite’s E2 catch can
So I bought the best elite can they had and aside from having very unclear instructions, included in the bag with the barb that taps into the intake tube, was an o ring and lock washer. The o ring doesn’t seem to fit anything and the best guess for the lock washer is that it’s for the replacement bolt they send for mounting the can.
Who has this can and found a use for the o ring?
thanks
Old Jul 29, 2018 | 04:09 PM
robert miller's Avatar
robert miller
Default ttt
Buddy all I can say is good luck with that can on the car. Let use know how it turns out with the NOS on her also. Robert
Old Jul 29, 2018 | 04:55 PM
ZNix's Avatar
ZNix
There's a good DIY thread on Camaro6. Its not a corvette, but maybe it can give you some ideas?
Old Jul 30, 2018 | 09:22 AM
subieworx's Avatar
subieworx
Did you get it with the clean side filter? If so that oring if for that.
The lock washer is supposed to go under the bolt that holds the bracket to the car.
Old Jul 30, 2018 | 12:10 PM
KyleL's Avatar
KyleL
Cruising
Yes, I ordered it with the clean side filter. The adapter the twist into the sump tank has an o ring on it and the other o ring is too big for it. Same with the filter that pops into the adapter. It has two o rings already on it and the other one is too big for that as well.
I figured that’s what the lock washer was for, so I’ll put that on there today, that’s no big deal.
I also included a pic of the hoses attached to the catch can. Is that how it’s supposed to attach? The instructions didn’t say how to attach it since the can pictured in the instructions uses the barbs and clamps
Old Jul 30, 2018 | 04:34 PM
subieworx's Avatar
subieworx
The fittings they include are wrong for that type of hose. That fitting should only be used with a braided hose and more specifically Fragola's Series 3000 braided hose.
Old Jul 30, 2018 | 09:53 PM
ZNix's Avatar
ZNix
The hoses seem to work for me. I used a lot of spit and pushed those suckers in there. Then got them pretty snug.
Old Jul 31, 2018 | 08:05 AM
GUSTO14's Avatar
GUSTO14
Kyle, have you gone to their website and checked through their instruction pages?
http://www.eliteengineeringusa.com/i...tructions.html
You could also give them a call. I installed a number of their products on my C5 over the years, including the Catch Can, and they were always very helpful in answering any questions I had.
Good luck and let us know what you discover... GUSTO
Old Jul 31, 2018 | 09:27 AM
subieworx's Avatar
subieworx
They'll work, but only because they are not under pressure. If they were under pressure they would blow apart in short order as the nut on the outside will destroy the hose as it is tightened down. The outer braid on the proper hose keeps the inner rubber hose from tearing when the nut is tightened onto the ferrule.
Lube for assembly, use WD40. I have tried everything out there and have assembled many AN fittings and this has always worked best for me.
Old Aug 1, 2018 | 03:51 AM
geewez's Avatar
geewez
There are a couple of videos on You Tube on the installation of the Elite catch cans.
Old Aug 1, 2018 | 11:13 PM
spinkick's Avatar
spinkick
I have a thread with written instructions on how to do it.
To Elite’s E2 catch can
