Unplug it and then Plug it back in and count the led flash sequence. That will tell you the software version. The current version is 8.6.1 the last I heard.
Quote:
Exactly Originally Posted by C5_Tom
383vett
close
- Member SinceApr 2003
- Locationmoraga ca
Liked:1,667 Times in 1,109 Posts
If you have the box and bought it new, there will be a sticker with the version of the unit on the box. 8.6.1 is the latest version. I just spoke with AFM last week.
MMD
close
- Member SinceMar 2018
Liked:1,650 Times in 1,053 Posts
Quote:
yep, you will be out $190 (which I found out I could have bought new for $160) and also you will bump your knee into the device often getting in the car. Finally, you may sometimes accidently tug on the Range device trying to open the hood latch 'cause both are adjacent to one another.Originally Posted by javenius
I understand the upside of using this device but are there any downsides?
Dcasole
close
- Member SinceOct 2014
- LocationAtlanta GA
Liked:2,728 Times in 1,936 Posts
Quote:
Your car will never go into 4 cylinder mode thereby causing a huge gas shortage and causing the hole in the ozone to grow largerOriginally Posted by javenius
ok now to answer your question no there are no downsides ....
Dave
Dcasole
close
so except for the 1st one .... I have never even remotely come close to doing the last two Originally Posted by MMD
Dave
ExploreMMD
close
Quote:
Dave
I have banged my knee a few times...only had the car a month now. I have also fumbled around trying to reach the hood latch and mistakenly tugged on the Range. The latch goes back a good way and since the car is so low it is not easy to visually see the latch.Originally Posted by Dcasole
so except for the 1st one .... I have never even remotely come close to doing the last twoDave
383vett
close
- Locationmoraga ca
Sounds like GM wasn't thinking of you when they designed your car or maybe you have a slow learning curve.Originally Posted by MMD
MMD
close
Quote:
have you even driven a C7 with a Range device?Originally Posted by 383vett
MMD
close
Quote:
I had asked if you had ever driven a C7 with a Range device. I didn't ask about a picture.Originally Posted by 383vett
is this the thingy you’re talking about? See post 4 above.
383vett
close
- Locationmoraga ca
Yup, that’s my car in my garage.Originally Posted by MMD
Dcasole
close
Mine has sat for a month also with no problem . The draw issue was fixed with the latest firmware update
Dave
Dave
vader86
close
- Member SinceSep 2001
- LocationAthens AL
- Veteran Field #1C7 of the Year - Unmodified Finalist 2021
- Veteran Field #2C4 of Year Finalist (performance mods) 2019
Liked:1,731 Times in 1,224 Posts
Quote:
Your exhaust will now kill all baby seals. It'll be ok.Originally Posted by javenius
MMD
close
Quote:
Yum..Taste like chicken.Originally Posted by vader86
