App sensor for nitrous window switch
Old Aug 9, 2018 | 06:59 PM
GRstylesZ51's Avatar
GRstylesZ51
Default App sensor for nitrous window switch
good afternoon everyone,
does anyone know what color wire I need to splice into for my window switch. I’d prefer to use a wire from the pedal(APP) as opposed to the TPS under the hood. It’s for my 14 C7. A diagram would help if anyone has that. The window switch will operate with falling or rising volts, just don’t want to hack up the harness.
thank you in advance
Last edited by GRstylesZ51; Aug 9, 2018 at 07:00 PM. Reason: Need to be more specific
Old Aug 11, 2018 | 05:43 PM
GRstylesZ51
It the yellow wire at the pedal if anyone ever needs this information.
Old Aug 30, 2018 | 11:35 PM
AlphaC7's Avatar
AlphaC7
4th Gear
Default Awesome.
Thanks for posting this information! I'm installing my NX plate kit right now and am using a NX digital window switch as well. The yellow APP wire is the signal you needed for throttle voltage? Worked well? Also, do you know the coil number and wire color for the tach feed?
Thanks!
Old Aug 31, 2018 | 08:46 AM
GRstylesZ51
Yes the yellow wire works great. I still have not been able to get a tach signal. Let me know what find. They say it’s suppose the be the black wire on coil # 7 but I was getting a really inconsistent signal sometimes it would work then other times it would sky rocket to like 34000 and cause the nitrous to turn on randomly.
Old Aug 31, 2018 | 10:22 AM
AlphaC7's Avatar
AlphaC7
4th Gear
Did you set the switch to cylinder 7 and coil on plug?
Old Sep 1, 2018 | 06:31 PM
AlphaC7's Avatar
AlphaC7
4th Gear
Default Wires that work for RPM signal and APP sensor.
Well. Since no one likes to respond.......here's some good information I discovered through trial and error. Coil 7. Use the Light green wire for RPM signal. APP sensor. Use the yellow wire as stated above. Enjoy the Juice.
Rob
Old Sep 1, 2018 | 10:36 PM
GRstylesZ51
Thank you, I try the light green wire for the tach tomorrow. How much you plan on spraying?
To App sensor for nitrous window switch
