Weird issue surging
Old Aug 10, 2018 | 04:17 PM
brookman's Avatar
brookman
Default Weird issue surging
2017 coupe automatic, 10200 miles.
This has happened 3 times now, and enough that it concerns me.
The selector is in the Sport setting.
The issue is as follows: I am driving along 25 - 40 mph and stab the throttle and immediately let off (like if someone cuts you off right after you start to accelerate) and within a second later, the engine surges and the car leaps forward, almost like lag. The surge is enough to cause concern about maybe hitting someone.
If I am driving and press the pedal to the floor , it shifts and accelerates just like you would expect.
Has anyone seen this?
Old Aug 10, 2018 | 04:27 PM
poughkeepsie's Avatar
poughkeepsie
I'm not an expert, but I would believe it has something to do with the programmed delay in the drive by wire throttle
Old Aug 12, 2018 | 03:25 PM
MorganMay's Avatar
MorganMay
I have seen similiar behavior with a quick stab on and off the accelerator at low speeds. My conclusion: it's normal and don't do that.
Old Aug 12, 2018 | 06:55 PM
brookman's Avatar
brookman
That is why I made the post, I wanted to see if anyone else experienced the same "issue" . Thanks!
Old Aug 14, 2018 | 04:13 PM
Internets_Ninja's Avatar
Internets_Ninja
With 8 gears it takes a moment to dig down to the right one. Then you let off the throttle. This is def a driver error issue.
To Weird issue surging
