Brake pads: Hawk DTC70/60 to Carbotech/PFC?
I'm currently running Hawk pads DTC 70/60 front/rear on my oem c7gs rotors, but I'd like to go to Carbotech or PFC for my next set. My tires are r888r 315/335 f/r, and I do 15-25min sprints during club trackdays.
Any advice on the best pad options? (Not to overly complicate, but since the front and rear pads won't wear out at the same time, if there are equivalents in Carbotech/PFC that will allow me to swap out one end at a time, that would be icing on the cake.) Much thanks!
Supporting Vendor
St. Jude Donor '11,'13
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam, I currently drive to/from the track and keep the pads on (tw200 tires kept on too). However I don't do much street driving other than that during track season. Off-season I drive with oem pads and MSS tires.
Supporting Vendor
Carbotech™ XP20™
The latest iteration of the highly successful XP™ series of compounds. XP20™ is a step up from the highly successful XP16™ compound. With an extremely aggressive initial bite, linear torque curve and excellent fade resistance the XP20™ is another major step in progression of the highly successful XP™ series line of compounds from Carbotech™. XP20™ has a temperature range of 275°F to 2000°F+ (135°C to 1093°C+). Carbotech™ XP20™ maintains our tradition of having the outstanding release and modulation that has made all other Carbotech™ compounds so successful. Carbotech™ XP20™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.Carbotech™ XP10™
When Carbotech™ unleashed the XP10™ to the general public it immediately gathered multiple regional, divisional, and national championships. The XP10™ has a very strong initial bite with a coefficient of friction and rotor friendliness unmatched in the industry. Fade resistance is in excess of 1475°F (801°C). XP10™ still maintains the highly praised release, excellent modulation and rotor friendliness that have made all Carbotech™ compounds so successful. Carbotech™ XP10™ is not recommended as a daily-driven street pad due to possible elevated levels of dust and noise.
I've used PFC-08s and 11s. 11s. were similar to DTC70 and 08s were similar to DTC60s, but they last longer.
I've also had terrible experience swapping pads between vendors. Especially if they've been properly bedded in. I know Hawk DTC60s and Cool Carbon brake pads did not like each other. I ended up having to hose down the rotors, let rust set overnight, then going out with some new DTC60 pads and stomping on them cold to get the surface cleaned off.
OK. I would run Carbotech XP20 front XP10 rear. This will be aggressive as the Hawks but way more rotor friendly in the long run you will end up saving money on rotors. If interested let me know a pad description is below.
Carbotech™ XP20™
When Carbotech™ unleashed the XP10™ to the general public it immediately gathered multiple regional, divisional, and national championships. The XP10™ has a very strong initial bite with a coefficient of friction and rotor friendliness unmatched in the industry. Fade resistance is in excess of 1475°F (801°C). XP10™ still maintains the highly praised release, excellent modulation and rotor friendliness that have made all Carbotech™ compounds so successful. Carbotech™ XP10™ is not recommended as a daily-driven street pad due to possible elevated levels of dust and noise.Newbie question: By Xp20/10 combo rather than a Xp20/12 combo?
Supporting Vendor
I suggest 10 to start because I don't know if your rear will get hot enough for the 12 to come into its heat range to work properly. You can always move up if you feel you need more in the rear.
archfarseer (08-28-2018)
