Key fob issue
Old Aug 26, 2018 | 03:55 PM
drivemewilder's Avatar
drivemewilder
Default Key fob issue
Let me apologize upfront as i'm not very active on the forums. I'm not great at searching for similar topics and finding solutions. My '15 stingray has given me zero problems since I bought it 2 years ago. It's only got 9700 miles on it. After returning home after a 1 month work trip, my key fobs (2) didn't let me in. I tried multiple times....no flashing lights, no door unlocking sound, nothing. When I did gain access inside, I got the dreaded "no key fob detected" message. Frustrated, I took a separate vehicle to work. That afternoon, both key fobs worked the first time I tried. So I drove it to the Chevy service dept and they tested both key fobs and indicated that both key fobs have a stronger signal than they are used to, needless to say I did not buy new batteries as I anticipated I would. The car started up with no problems the rest of the day. This morning...1 key fob didn't work. I drove the car using the key fob that does work and when I returned home, I tried the non-working key fob and sure enough it's working just fine also. In short, over 2 days both key fobs work flawlessly multiple times after the car has started and I drive around. But no guarantees that it'll work tonight or tomorrow morning after it sits in the driveway for a few hours. I did monitor the car battery this morning while I was driving. It moved slightly but seemed to hang out at around 13 volts. There was a checkmark next to the battery indicator and I have not gotten a low battery warning. Any help is appreciated.
Old Aug 26, 2018 | 04:48 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Replace the FOB batteries (both). Here is a chart to help you in the decision making process for no FOB found.
http://forums.corvetteforum.com/c7-g...s-and-rke.html
Elmer
Old Aug 26, 2018 | 05:15 PM
Maxpowers's Avatar
Maxpowers
Its difficult to accurately test the condition of key fob batteries. Replacing every 12 to 18 months is a best practice
Old Aug 26, 2018 | 05:31 PM
badhabit_wb's Avatar
badhabit_wb
Mine did the same thing Friday. It's a 2032 battery. Took a couple of minutes to change it out and it works fine now. Mine is a 2015 too.
Old Aug 26, 2018 | 05:37 PM
gooddog's Avatar
gooddog
On a lark, watch for exterior electrical "noise" in and around the car if it occurs again. RF noise could disrupt the fob signal.
Strange, but possible. (like an air compressor or refrigerator running nearby?)
Old Aug 26, 2018 | 08:18 PM
drivemewilder
Thanks all. I took the advice and replaced the batteries. Both are working so far, but the real test will be tomorrow when the car has sat for 12-14 hrs. I appreciate it your help.
Old Aug 27, 2018 | 08:49 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
That is the EXACT problem I had with my 2014 Z51. Replacing FOB batteries totally cleared up the problem
To Key fob issue
