Help selecting correct Powerstop brake pads
I have a 2017 C7 Z51 and am trying to order Powerstop pads for it. On Powerstops web site it has two options for the Z51.
OPTION # 1 - Stingray Z51-J55 Brake Package - ReDesigned Full Cast Brake Rotors for Improved Cooling
OPTION # 2 - Stingray Z51 - J55 Brake Package - OE Designed Co-Cast Brake Rotors
There are completely different part numbers for the two options. I called power stop and they suggested I decode the VIN to find out which I did but couldn't find the answer. On the web site I was able to select the year and sub model of the car which gave me the above options. This tells me there must be both options for the 2017 model year. Any help determining which rotors would be much appreciated...
In looking at other web sites to order the Powerstop pads from this option doesn't come up at all, maybe its not a big deal. Doesn't make sense to me??
Thank You
http://ampdautosport.com/brake-pads/corvette/
Thank You
