Ignition timing @ WOT
Old Sep 21, 2018 | 12:59 AM
billiardcue's Avatar
billiardcue
Default Ignition timing @ WOT
How much ignition advance at WOT, as in drag racing, does an LT1 like for best performance?
Old Sep 21, 2018 | 09:23 AM
robert miller's Avatar
robert miller
Ever car r motor is just a little bet diff on a set man so that is really hard to say on your engine. You can put the very same parts into two diff motor builds & each one will not be the same. One will like a little more timing r less & the other may like more gas or what ever in it to get the peak power from it.
But to get back to your question are you talking about a 100% stock LT1 more r what here. Robert
Old Sep 21, 2018 | 09:28 AM
JHEBERT's Avatar
JHEBERT
Robert is right. You need to datalog some WOT pulls to see where it’s happy. You’re going to find a point where it may not detonate, but you still don’t want max tolerable timing but rather a couple deg less. I’m hitting 28deg advance on an lt4 but that same timing for another combination could spell disaster. Cylinder pressure and octane are only part of the equation, but they are big players.
John
Old Sep 21, 2018 | 10:26 AM
billiardcue
John
LT1 A8 with MSD manifold, Katech throttle body, AFE intake, ARH headers.
Logging 1/8 mile passes with EFI Live the advance varies between 17 to 20 degrees at WOT.
It pulls timing up to -10 degrees at shifts.
Old Sep 21, 2018 | 02:54 PM
JHEBERT's Avatar
JHEBERT
Timing pull during shifts is normal, as some tuners command 10deg or so of min timing between shifts. I don’t like that, but it stops the car from falling on its face during a shift. I’m not so sure it’s the best thing for clutch pack life (at least on the very high HP stuff). Actual min timing would be a negative number during a shift. I would also GUESS that you should be between 20-24deg depending if you are looking around peak torque of peak HP. If you don’t think it’s happy, throw. 2 Deg in it and make a pass data logging. If you want to be on the edge, make it tickle the knock sensors and come back a degree in those areas, but even that won’t be night and day performance and it’s not worth the risk IMO.
Old Sep 22, 2018 | 01:15 AM
Internets_Ninja's Avatar
Internets_Ninja
Timing should peak around 24 degrees before peak torque and taper off to about 22 degrees at redline for that setup. Some cars will like a little more, some won't. Depends on how the car responds with your mods and the fuel you use.
To Ignition timing @ WOT
