Rear right side computer
Old Sep 22, 2018 | 09:31 AM
Rhettvette's Avatar
Rhettvette
Default Rear right side computer
Looking to find out the function of the rear right side computer by the battery. What does in control? Thank you
Old Sep 22, 2018 | 11:55 AM
laserdude2215's Avatar
laserdude2215
If you are talking about the underside with an automatic transmission, then that is the transmission control module.
Old Sep 22, 2018 | 03:43 PM
Rhettvette's Avatar
Rhettvette
Thanks for the reply, No I am looking for the function of the passenger side computer in the trunk { vert ) in this case next to the rear fuse box. There is a computer on both sides
of the fuse box.
Old Sep 27, 2018 | 10:47 AM
ersatz928's Avatar
ersatz928
The unit on the left, with the diagonal fins is the stereo amplifier. The unit on the right is the "Chassis Control Module K38"...…...not sure what that controls (it does not control the Mag Ride or the eDiff, or the ABS/Traction control.) I am digging thru the wiring diagrams to figure that out.
Old Sep 27, 2018 | 11:17 AM
Rhettvette's Avatar
Rhettvette
Default Right rear computer
Thank you for your reply, I can now ask the
Dealer. I can at least have a function
Description to refer to so can ask a tech.
Thanks again
To Rear right side computer
